Author Topic: The Cambo Actus: A Gem!  (Read 7659 times)
« on: June 03, 2016, 02:20:58 »
I have a whole shelf or two of focus rails and another one with bellows and/or technical cameras. Some of them are tiny like the old Spiratone camera, which has all the view-camera moves and is of the size to fit a mirrorless camera. Sitting right next to it is a Rollei X-Actus 2 and it weighs over 14 lbs. Then there are the tilt/shift lenses, of which I have three and ever a tilt adapter that only has one fixed angle. And of course, my old standby, the Nikon PB-4 Bellows System.
So, when I finally had time to check out the new Cambo Actus for the Nikon mount, I was in for a surprise, and a pleasant one at that. This little gem, while not perfect, is one of those pieces of equipment that fits so well in my hands that I knew right off that I will love using it, and I already do.
It was a little hard to find one that you didn’t have to wait weeks for and the various adapters were another problem. Luckily, I remembered a company I had purchased a Medium Format camera from years ago, and they know all this stuff: Capture Integration out of Atlanta, Ga. They put together a system that had everything from soup to nuts, all assembled and ready to go. I went with that over waiting for who-knows-how-long, and hunting down all the parts for myself.
This little beauty’s body measures 5.9 x 3.9 x 6.7" (15 x 10 x 17 cm) and weighs 2.2 lb (1 kg), not ultra-lite, but have you picked up a technical camera lately that is any lighter? And no, it does not have all the movements, but it has the ones I use most and has camera bayonets for Nikon F, Canon EOS, Canon M, Leica M, Sony E-mount, MFT mount, and Fuji X.
Of course I did not find a bayonet for the Pentax K cameras, and within a couple of days of emailing the manufacturer in Netherlands, they agreed to design the first one for my new Actus camera, which I will have pretty soon. As of now, I have the Nikon and the Sony-E-mount camera adapters on hand.
It is important to understand that the front-standard on the Actus is fixed, while the rear moves, which is just what I want, and what any focus-stacker requires. The front-standard has 360º swing, and front tilt of +10º, -9º, each with their own geared knob. The swing and tilt movements on the front standard rotate around the optical axis, which is handy.
The rear-standard has Rise/Fall of +0.5”, -0.6” (+12mm, -15mm) with its both geared knob and locking knob, and a rear shift of +/-0.8” (20mm) with a locking knob.
As for mounting lenses, the Actus has a sturdy fork adapter that locks in place smoothly (and firmly) in one movement. Voila! Lens adapters come in a variety of formats, including M39, 24mm WA, Leica R, Nikon F, Canon EOS, Hasselblad, Mamiya RZ/RB, Mamiya 645Pro TL, Pentax 645, and with the standard Copal #0 and #1 holes.
The bellows is a dream come true. I am used to wrestling with my other bellows, mounting and unmounting them. With the Cambo Actus, it is all magnetic. The bellows snaps into place, front and rear, in a second and must have some of those rare-earth magnets or something. They fit tight!
As it turns out, the standard bellows turns out to be perfect for me, since with the Nikon D810 (for close-up work) I am not looking at shooting at infinity. The standard rail that comes with the Actus expands from 6” to 8.5”, which is more than enough for the lenses I work with. However, there are Wide Angle Bellows (one fold), Long Bellows (30 cm), and Macro Bellows (45 cm) available as well as special rails to match them.
A brilliant and easy-to-use feature on the rear-standard is a lever that allows you to rotate your camera from horizontal to vertical and back in one movement. How nice is that! The Actus also takes my Nikon D810, but if I want to add on a wired remote (Nikon MC-30), which I am used to, I need to add a tiny extension or force the cord a little. I am already used to the extension with my Nikon PB-4 bellows, so I do that.
And this little beastie feels like the precision machine it is. The whole thing fits in a Pelican Storm case iM2050, and comes packed in a foam piece that fits right into the iM2050 perfectly.
As for what I don’t like about the system or “wishes not granted,” I don’t like the fact that to change camera bayonet mounts on the rear standard requires 4 screws, and about a minute of my time, and worst of all fiddling with those tiny screws. I wish they had offered mountable adapter plates for each camera, so we could just switch them out with no hassle. Although I don’t need it, I would prefer that BOTH front and rear standards move, but that is not a real problem.
I love that the rail is Arca-Swiss compatible, which is all that I use. And again, I LOVE the heft and smooth feel of fine machinery on something I will use just all the time. I use it on the Swiss-Arca Cube C1 (with knob) and can flip it using the C1 so that it is exactly 90º, and still it is sturdy.
As what I do with it, I use it with any number of exotic industrial lenses, like the El Nikkor 105mm APO, the Printing Nikkors, and many others. Since I am not going for infinity focus with this system (but you can with a mirrorless camera), I can do all kinds of close-up and macro stuff with an elegance of movement unknown to me until now. Do I recommend it? I believe you know my answer to that. I love it.
Here is a little video of the system, for those interested:
https://vimeo.com/120736327
Re: The Cambo Actus: A Gem!
« Reply #1 on: June 05, 2016, 14:26:17 »
I would think that there would be some interest in this remarkable camera.
« Reply #2 on: June 05, 2016, 14:55:26 »
Michael, I am. I just have no patience, skills and gear to follow or even try. Big fan of your work. I´m so happy you found this new help so I can continue enjoying your work.
  Thanks for sharing
« Reply #3 on: June 05, 2016, 15:46:02 »
  Thanks for sharing
Thanks, but as you know, misery loves company!
bjornthun
« Reply #4 on: June 05, 2016, 19:09:04 »
Cambo also offers the Actar 24/3.5, which I understand is a rehoused Samyang 24/3.5. The Actar 24/3.5 is intersting only for mirrorless users, since the DSLRs have such a long flange distance. The Actar 24/3.5 makes the Cambo Actus intersting, since it could provide all the needed movements. There are also modern digital lenses from Schnider-Kreuznach and Rodenstock.
« Reply #5 on: June 07, 2016, 23:26:41 »
looks very good actually! How would you compare it to the Rollei XAcT?
« Reply #6 on: June 07, 2016, 23:51:19 »
I did not respond because I expected you to write about the actual handling in the field and studio.
The lenses you were talking about do not have a huge image circle and supercorrection you need to enjoy
the movements  so I thought which lenses will Michael use? Which topics will he present?
Might this be an option for me as a "Sinar for the road"? Or do I better take the Sinar plus a large
umbrella or tent for weather protection?
So I still wait in the bushes of this thread to see what Erlewine will make of the GEM.
love
Frank
Kamosor
  • cAPO di tutti capi
« Reply #7 on: June 12, 2016, 02:16:26 »
This is very rare HASSELBLAD T/S adapter from ebay: seller's nick - fataligallery. You can check another compact version Flexbody, too:
http://harrysproshop.com/Hasselblad_Flex/hasselblad_flex.html
« Reply #8 on: June 12, 2016, 03:01:09 »
A system the size for mirrorless cameras like the A7rII, the Spiratone, system. This is a system I have on hand, but probably will sell it because I use the larger DSLRs.
The Spriatone does all of the movements of the large technical cameras, but fits a smaller camera.
If you are interested in owning this rare system, let me know.
Kamosor
« Reply #9 on: June 12, 2016, 10:32:51 »
The ARCA Swiss Universalis DSLR weighs 1,2 kg with bigger knobs. The Silvestri Flexicam is compact, too.  The Rollei x-act is solid as a rock,  has all movements front and back standard, but weighs 4.3 kg.
https://www.youtube.com/watch?v=eaqOupzx_5M
http://www.silvestricamera.com/eng/prodotti_eng/documentation/flexicam%2009.pdf
Kamosor
« Reply #10 on: June 12, 2016, 11:26:01 »
The GFAE CAPcam is a huge and expensive fully computerized view camera.  You set the monitor 3D focus points, and the machine will automatically set the angles.
https://www.youtube.com/watch?v=NZtK9Q0mChg
https://www.youtube.com/watch?v=CcVtFOSHnFs
The set CAPcam and Cambo studio stand:
http://www.getdpi.com/forum/medium-format-systems-and-digital-backs/55769-watch-photography-my-journey-so-far.html
