Author Topic: Backlit Azalea  (Read 2254 times)
Andrea B.
  • Technical Adviser
Backlit Azalea
« on: May 27, 2016, 03:33:49 »
Backlit azalea flowers and leaves from my yard today.
Re: Backlit Azalea
« Reply #1 on: May 27, 2016, 03:57:06 »
very crisp images , nice yellows
Tom Hook
  • Tom
Re: Backlit Azalea
« Reply #2 on: May 27, 2016, 04:04:08 »
It's nice you have found things to photograph in your own yard, and then to have photographed them to such good effect.
Re: Backlit Azalea
« Reply #3 on: May 27, 2016, 04:24:54 »
Very successful use of the backlight to create the luminescent effect of the flowers and the leaves.
Re: Backlit Azalea
« Reply #4 on: May 27, 2016, 04:35:09 »
I particularly like the first one. Vivid color, contrast and very 3D like feel. Beautiful shot.
Lowell
  • Fascinated by photography
    • lowell harris photography
Re: Backlit Azalea
« Reply #5 on: May 27, 2016, 05:06:07 »
Andrea,  All of these images are just beautiful.  If you don't mind, what lens and settings were used.  How did you arrange for the back lighting?
Really great.
Lowell
Lowell Harris
Andrea B.
  • Technical Adviser
Re: Backlit Azalea
« Reply #6 on: May 27, 2016, 05:22:38 »
Thank you everyone.  :)
Lowell, I was using the Coastal Optics 60/4.0 on the D810. The deciduous azalea is very tall, so I stood under it and shot the flowers and leaves against the very bright sky. I slightly overexposed to ensure the the leaves were bright. Darker stem areas were lifted slightly during conversion.
These photos are actually crops from one large photo. The D810 + CO60/4 is capable of capturing great detail so such crops are possible. Here is a small version of the original showing some vignetting from the specialized hood used on the CO60 to prevent hotspotting at high magnifications. (Of course I forgot to remove it when using the lens today!)
It's always surprising how much light actually shines through leaves.
Lowell
Re: Backlit Azalea
« Reply #7 on: May 27, 2016, 05:26:03 »
Andrea,  Thanks for the explanation.  I like the way you have done this.
Lowell
Lowell Harris
Andrea B.
  • Technical Adviser
Re: Backlit Azalea
« Reply #8 on: May 27, 2016, 05:40:56 »
Here is an unresized crop from another photo of the yellow-orange azalea showing one of the anthers which has released its pollen.
Andrea B.
  • Technical Adviser
Re: Backlit Azalea
« Reply #9 on: May 27, 2016, 05:46:20 »
Another crop, downsized 50%.
Azalea anthers and pollen covered stigma.
beryllium10
Re: Backlit Azalea
« Reply #10 on: May 27, 2016, 06:13:11 »
I also like the original images a lot.  The third is a very appealing composition, I like the aspect ratio, the layering of the flowers across one another and the juxtaposition of bright oranges and bright greens.  I find it difficult to make high-key photos like this.  In raw conversion and processing I keep thinking "I'll just add a little more contrast for better definition".  Eventually I realise that I've destroyed the lightness I was aiming for, that is so nicely captured in these images.
John
Re: Backlit Azalea
« Reply #11 on: May 27, 2016, 08:59:09 »
Nice job! Your close-up work keeps getting better and better.
Re: Backlit Azalea
« Reply #12 on: May 27, 2016, 10:15:48 »
This is wonderful, lovely Andrea! Reminds me of these old botanical
books with drawings of the plant features. You made my day!
stenrasmussen
Re: Backlit Azalea
« Reply #13 on: May 27, 2016, 10:23:38 »
'Graphicoloural'...very attractive stuff Andrea!
Andrea B.
  • Technical Adviser
Re: Backlit Azalea
« Reply #14 on: May 27, 2016, 17:34:51 »
Sometimes we just see a cool image waiting to happen by sheer luck. I don't think I really did much except take the photo.  ;D   But thank you everyone anyway.  ;)
John, the high-key look in this case appeared almost on its own because of the backlighting. A few areas between leaves had to be slightly brightened in the editor using NX2 colour points to select only the sky. I may go further with that and entirely remove the cyanish sky because it would make an interesting print with a 'pure' white background.
BTW, I've now downloaded the Nik package to have continuing access to colour points for just such work when I finally lose NX2 due to OS upgrades. Of course we'll probably lose the Nik package eventually also. Oh well.
Michael, with the dynamic range and detail capturing capability of the D810, close work is made much easier. And I'm finding that the idea of croppability (sp?) with a 36MP camera is not to be dismissed. It is quite useful actually. I "saw" those sub-compositions in the photo and just had to try them.
I did not have the CO60 on extension, so I could not get as close as I liked to those pollen grains. I may reshoot those again today and attempt to get closer. That is undoubtedly the sharpest lens I own, although I have not tested my UV-Nikkor or UAT, both of which are no slouches in the sharpness department, side-by-side with the CO60 on the same subject.
Sten & Frank - Yes, there is a 'graphical' look to this. It almost seems unavoidable because of so many MP. If you brighten a photo's midtones even by a little bit and add a touch of clarity or detail, this look seems to pop out. In this case it worked well.
