Author Topic: ais35rendering  (Read 1547 times)
stenrasmussen
ais35rendering
« on: May 18, 2016, 19:52:15 »
Finally got my 35/1.4Ai-S back to working order after tedious CPU modification and cleaning. It is one hell of a lens to assemble due to intricate cam arrangements. But it lives to render more from this world and here is one example from a flower at our front door (shot at f/1.4). No fancy PP involved - just curves, saturation, layering and sharpening played with.
Re: ais35rendering
« Reply #1 on: May 18, 2016, 19:57:00 »
real colors?????
stenrasmussen
Re: ais35rendering
« Reply #2 on: May 18, 2016, 20:25:38 »
real colors?????
Actually, yes. Here's a small version of the jpeg SOOC.
Re: ais35rendering
« Reply #3 on: May 19, 2016, 02:51:43 »
Nicely exaggerated field curvature which is fitting to the subject.  Did you use an extension ring, or was the lens set at its shortest focusing distance?
Peter Shawhan
Re: ais35rendering
« Reply #4 on: May 19, 2016, 03:24:25 »
This photo illustrates well what people mean when they say that the 35mm f/1.4 AIS  has a dreamy quality, unusual bokeh and shallow depth of field when used at maximum aperture, as compared with its rather different qualities of high sharpness and fine detail when used between f/2.8 and f/5.6 or so.  I like the photo -- thanks for posting it.
I gather that you have a fair amount of experience working on lenses, as indicated by your willingness to tackle and successful completion of a CPU modification to this complex lens.  I haven't tried anything like that.  I have a Df, so I can use the 35 f/1.4 AIS via the "non-CPU lens" menu options.  While that means the lens can only be used with manual or aperture-priority settings, it's not difficult to use that way.  It says a fair amount about the quality of this lens that it is still delivering good images on DSLRs 35 years after the AIS version was introduced in 1981.
stenrasmussen
Re: ais35rendering
« Reply #5 on: May 19, 2016, 07:50:10 »
No extension involved, just near min. focus distance.
stenrasmussen
Re: ais35rendering
« Reply #6 on: May 19, 2016, 07:53:21 »
The lens is temperamental and has multiple uses as you say, dream on wide and sharp when choked.
Re: ais35rendering
« Reply #7 on: May 19, 2016, 15:14:37 »
Thanks.  Apparently the lens is worth trying to investigate its multi-faceted character.
