Author Topic: Mirror mirror mirror  (Read 2808 times)
« on: April 28, 2016, 23:05:02 »
An odd portrait. Part of a "normal" shooting.
C&C always welcome
Re: Mirror mirror mirror
« Reply #1 on: April 28, 2016, 23:09:54 »
Appreciate your keen eyes, as always.  You might want to try some "dehaze" function in ACR to make it a bit clearer?
« Reply #2 on: April 28, 2016, 23:44:44 »
Beautiful image, I like the hazy look.  Though I do feel there is too much dark negative space at the bottom that throws the balance off.  I feel a crop would help
« Reply #3 on: April 28, 2016, 23:48:43 »
My first thoughts exactly. However, after having studied the picture several times, I ended up with suggesting more or less the similar framing as the author chose in the first place. The interplay of positive and negative spaces occurs on several levels of scale and include brightness as well as colour. Well done.
elsid
« Reply #4 on: April 29, 2016, 00:18:54 »
Very artistic and in good taste Paco.
« Reply #5 on: April 29, 2016, 00:22:33 »
Paco teases us and shields a beautiful woman from us with his artistry :)
RBSinTo
« Reply #6 on: April 29, 2016, 01:14:09 »
This is a wonderful image that is a visual feast.
There is the subject and her reflection in the mirror as well as a second, less distinct rendering of that same twosome slightly lower down and to our right, all enveloped in a mysterious haze.
As for the negative space at the bottom, I'd suggest horizontally cropping some of it out at the point where the diagonal descending from right to left meets the frame edge to our left.
Robert
I shoot with film. That's film. F...i...l...m. You remember film. It was in all the papers.
« Reply #7 on: April 30, 2016, 02:15:47 »
Thank you all for your input. Because of the different opinions is difficult to answer to you...I will find the nef and post it here in case anyone will like to give it a try.
  Do or do not. :)
« Reply #8 on: May 03, 2016, 16:21:46 »
As promised:
   https://www.dropbox.com/s/trp6tovqdzqggbs/_QCO9116.NEF?dl=0
  If you feel like it, have fun!
« Reply #9 on: May 03, 2016, 17:20:12 »
I only wanted to make the lady's image a bit clearer.  But when I use the "dehaze" filter, the color changed a lot, and the vignetting increased.  Then I try to adjust the color as close to the originally posted, the dehaze effect decreased.  The result is very close to the original, but hopefully it is a bit clearer, as I say.  I adjusted the vignetting manually but didn't remove it completely.
Personally I thought your framing is good, so I tried to be true to your original trimming.  The result is 4 pixel wider, though.
« Reply #10 on: May 03, 2016, 20:31:25 »
Akira,
  I see more clearly her face in the mirror and some objects -like the world ball- I like your version better in subtle but noticeable ways. Thanks a lot for taking the time and sharing it.
« Reply #11 on: May 03, 2016, 22:34:53 »
My extravagant take on a beautiful image regardless of the processing :)
« Reply #12 on: May 04, 2016, 01:45:32 »
Akira,
Paco, thanks for kind words.  Glad you like it!
« Reply #13 on: May 04, 2016, 15:55:24 »
Jakov,
 that is not extravagant. The main point of the shot was the character wearing that feathery top in different situations. You just found another way of pointing it out. Spot on!
  Thanks for your vision
