Author Topic: High Res 3D Video  (Read 3256 times)
High Res 3D Video
« on: April 18, 2016, 19:29:40 »
Hi. Thought that might interest you also. I own and love their products
Kolor I mean and I always was fascinated by theit 3D video renderings
they showed on Photokina:
www.kolor.com/2016/04/15/meet-omni-and-surf-on-gopro-vr/
Re: High Res 3D Video
« Reply #1 on: April 18, 2016, 19:39:08 »
« Reply #2 on: April 18, 2016, 20:42:02 »
Akira. I ran into some auto correction by the forum software.
Probably the Autocorrect of the first letter H instead of h which I typed.
In a second step the Autocorrect puts another http in front.
test
http://Http://test.test
http://test.test
« Reply #3 on: April 18, 2016, 20:44:41 »
Confirmed
Andrea B.
  • Technical Adviser
« Reply #4 on: April 19, 2016, 02:15:58 »
?? We don't have Autocorrect.
If the software recognizes a URL, then the URL will be encoded. But perhaps the software cannot determine when a URL is improperly formatted.
Inside the code box are some URLs. The last three are badly formatted. The software cannot recognize all of the bad formats. When placed inside a code box, the forum software will not modify the URLs or attempt encoding.
Code: [Select]
OK   www.nytimes.com
OK   http://nytimes.com
OK   nytimes.com  BUT INCOMPLETE
BAD  Http://nytimes.com CAPITAL LETTER
BAD  htp://garbage.com MISSPELLED
BAD  www.nytimes .com  DISCONNECTED
Here is how the software handles those URLs. The two properly formatted, complete URLs are recognized and encoded. The incomplete URL is ignored (but will work in a browser). The badly formatted "Http" URL and the disconnected URL are partially recognized, but improper encoding results. The misspelled URL is not recognized.
OK   www.nytimes.com
BAD  http://Http://nytimes.com CAPITAL LETTER
The URL recognition software most likely parses phrases without regard to capitalization becaused web adresses are not sensitive to that. Thus the software did recognize the "Http" URL and tried to encode it. I agree in theory that this is bug, but only so much recognition can be built into software for recognizing badly formatted phrases.
To illustrate the parsing comment -- if you type the following into a browser adress bar, you will be taken to the New York Times website.
Code: [Select]
Http://nytimes.com
HTTP://NYTIMES.COM
« Reply #5 on: April 19, 2016, 10:45:46 »
thank you.
When I type in a new line, which programm autocorrects the first letter into a capital?
h ... does not always happen, esp. not on the big machine
Happens on the phone though. So this might be a "feature" of the phone, not the Website?
Andrea B.
  • Technical Adviser
« Reply #6 on: April 20, 2016, 16:15:20 »
Again, we have no Autocorrect set on the forum software.
There is no way for me to know what your phone or other machines might do.
« Reply #7 on: April 20, 2016, 17:06:05 »
Allright. Thank you. A chain reaction obviously.
now I know how to avoid this. Thank you again.
