Author Topic: Question regarding Circular Polarizer  (Read 3620 times)
« on: April 09, 2016, 12:15:28 »
I've an amateurish question regarding usage of circular polarizer filter. Whenever I've used Nikon CPL on my 18-200 mm zoom (with D200), I was satisfied with the results. The Nikon samples (example below) doesn't look dull or flat to my eyes (or may be they do, tell me please if you feel they are dull).
But when I used BW polarizer on Fuji 18-55 zoom (with X-T10), I did not get same results. The photos looked fairly dull and flat.
Questions:
- Does the Fuji results below look different because of polarizer or because general light conditions were different?
Do the results/effect vary depending upon which system you are using? (DSLR vs Mirrorless)
- I can go out and click more shots to compare side-by-side. But I’m curious to know what your experience have been with CPL filter.
Re: Question regarding Circular Polarizer
« Reply #1 on: April 09, 2016, 12:58:24 »
Different scene contrast is what comes to mind first. Camera and Filter seem innocent.
First one looks like Greek summer light at midday. Second one is hazy late afternoon possibly autumnal
« Reply #2 on: April 09, 2016, 14:28:40 »
Sorry no experience with mirrorless.
Your pictures seem fine to me.
I´ve been using polarizing filters (cpl now) for more than 30 years because I like the result they provide.
They are supposed to provide rich and vibrant colors because they remove reflections. I don´t call it dull. I call it beautiful colors, like in your first pic.
« Reply #3 on: April 09, 2016, 14:41:31 »
Anirban, why don't you make the same photo with and without the circular polarizer?
You will know immediately which is to you liking :)
I used to use polarizers a lot. I don't have a valid reason why I stopped...
BEZ
  • RC51
« Reply #4 on: April 09, 2016, 15:28:14 »
Photoshop!  :)
Cheers
Bez
« Reply #5 on: April 09, 2016, 16:31:14 »
Thank you everyone for your valuable comments.
I'm too lazy for that, Jakov.  ;D Jokes apart, I will certainly do that. I always forget about it, but now I will remember, hopefully.
« Reply #6 on: April 09, 2016, 18:41:40 »
I second Jakov in his relevant answer.
I use pola filters only to enhance cloudy landscapes and to eliminate any glass or water reflections. ;)
« Reply #7 on: April 09, 2016, 20:29:41 »
You'll have to shoot exact A-B tests* to know if the hypothesis has value.  I suspect that if you did test side-by-side, you'd see no difference that could blamed on the CPL filter.  Greek daylight is famously contrasty, and San Francisco is equally famous for having a marine-influenced atmosphere.
*Same scene, same time, same angle of view.
« Reply #8 on: April 10, 2016, 03:47:13 »
Thanks Francis, Keith. Point taken.
