Author Topic: Nikkor 15mm f/5.6  (Read 3792 times)
RonVol
Nikkor 15mm f/5.6
« on: March 26, 2016, 11:12:58 »
One of my favourite lenses  :)
I've accumulated a little collection of them through the years.
Here's a shot showing all for the different styles of packaging that was used for them.
RonVol
Re: Nikkor 15mm f/5.6
« Reply #1 on: March 26, 2016, 11:16:35 »
Here are scans of a brochure for the f/3.5 version.
« Reply #2 on: March 26, 2016, 11:26:46 »
Both versions are fine lenses and show remarkable low barrel distortion for subjects in the middle to distant range. Up close their CRC creates significant barrel distortion, just like the 35/1.4. Central sharpness is excellent, although the f/5.6 struggles more on a digital camera due to its uneven colour rendition across the frame and its corners can be on the slightly soft side. The f/3.5 is largely devoid of these problems. Their CA tends to be of the lateral kind and thus easy to remove.
They are very prone to flare when bright light is just outside the frame, and the f/5.6 being extremely susceptible to flare will do so on the slightest provocation, even the presence of ordinary sky light is enough.
The f/5.6 has built-in filters on a turret and the f/3.5 uses the same small rear filters as the larger 13/5.6 and the (in comparison) tiny 16/2.8 Fish.
The 15/5.6 was the first occasion I encountered of a Nikkor with severe decentering issues, by the way. I finally had to have my sample replaced by Nikon, as the factory did not manage to get it in proper working order despite the lens being returned twice to Japan. The "new" sample has served me well since 1973, though.
RonVol
« Reply #3 on: March 26, 2016, 11:29:43 »
According to this magazine ad from 1978; a Nikkor 15mm was used for filming several scenes in the original Star Wars movie.............in particular the scene where the Millennium Falcon (a Corellian YT-1300 light freighter) is seen jumping into hyper-space from within the confines of the cockpit.
RonVol
« Reply #4 on: March 26, 2016, 11:44:33 »
Very interesting.
First I've heard of that problem with a Nikkor.
« Reply #5 on: March 26, 2016, 11:59:49 »
Oh well, that was the *first* time. Alas, it wasn't the last. I have had lenses straight out off the maker's box with so bad decentering the lens couldn't be focused. And not just ultrawides either: it happened with a 400/2.8 VR.
« Reply #6 on: March 26, 2016, 12:02:39 »
To elaborate on the stated advantage of shooting in a cramped interior with these 15 mm class lenses.
Here is an interior from my small red car, a Peugeot, for which "cramped" is an understatement. Still, the 15 mm (the f/5.6 in this case) made my day.
« Reply #7 on: March 28, 2016, 00:38:46 »
What a nice set of boxes, now we need to see the lenses ;)
