Author Topic: Fixing a Nikkor 105mm f/2.5  (Read 14452 times)
Alaun
Re: Fixing a Nikkor 105mm f/2.5
« Reply #15 on: March 20, 2016, 09:36:00 »
Works as well: Put it  into a freezer and later a little heat on the outside part (just tested this a couple of weeks ago)
Wer-      Dro-
      ner         ste
« Reply #16 on: March 20, 2016, 10:18:51 »
Yes that is the basic idea of how it works - But also aluminum expands more than glass ;)
Richard, What do you mean by Pitch?
« Reply #17 on: March 20, 2016, 12:05:11 »
He meant "tar", I suppose.
« Reply #18 on: March 20, 2016, 12:22:54 »
yes, Akira-san said it correct, black tar. :o :o :o
« Reply #19 on: March 20, 2016, 13:00:26 »
Ok,,, next question; What do you mean by Black Tar?
« Reply #20 on: March 20, 2016, 16:06:47 »
Black tar is basically the black liquid goo that careless dinosaurs step into, leading to their death :o :o :o
« Reply #21 on: March 20, 2016, 16:08:08 »
OK, and where do you apply it if your not prehistoric?
« Reply #22 on: March 20, 2016, 19:35:05 »
The pitch or black tar is used to fix the lens to the rotating platform when they are ground.  Perhaps it is also used as anti-reflection paint and applied to the edges of the lens elements?
« Reply #23 on: March 20, 2016, 19:57:32 »
Thanks,,,
But it still really doesn't make any sense to me ::)
Flat black paint is used for the glass edges and the rear opening on some lenses,,,
« Reply #24 on: March 20, 2016, 20:07:59 »
Well, I was just guessing its use as anti-reflection method.  But tar is pitch black!
« Reply #25 on: March 20, 2016, 20:15:54 »
 ;D
« Reply #26 on: March 21, 2016, 01:51:47 »
Hello sorry for not being clear  :o :o :o
some lenses have it to glue it with its casing. i was shown once where it was baked to separate it from the glass. i asked and i was told "pine sap" basically pine resin. the reason thy probably use this is because it is pliable when warm. according to the repairman, telescopes use this more than camera lenses. i guess this is an old technique
« Reply #27 on: March 31, 2016, 20:59:52 »
*sigh, well, the Utrecht event came close and I had to hurry.
Thus I did not take as many photos as planned.
Bringing the f-stop klick spring back.
« Reply #28 on: March 31, 2016, 21:09:08 »
moving on. Putting little screws back in places.
Carefully following the notes taken on the protective sheets of (news)paper.
« Reply #29 on: March 31, 2016, 21:14:31 »
