Author Topic: Infinity focus adjustment  (Read 3331 times)
« on: March 12, 2016, 23:30:20 »
I recently dissembled my Nikkor 105mm 1.8 and had to take apart the focus ring to clean a helicoid.  This meant putting it back together as closely as it was prior as I could, since it sets the infinity focus.  Today I tested it out.  Aiming at a radio tower probably around 8 miles away on a tripod with magnified liveview, I set the lens at f/1.8 and found that it was focusing in just a bit before the lenses infinity hard stop, hitting the infinity hard stop threw it out of focus somewhat.  I have two questions.
Was this a good testing method?
Does my result entail any performance degradation I am unaware of?  I am assuming I am losing a bit of close focusing distance, but I am just guessing.
Re: Infinity focus adjustment
« Reply #1 on: March 13, 2016, 07:45:50 »
I have used this method with my "Scotch Tape Infinty" lenses, the 135/2 Ais and 84/1.4 Ais.  As I recall, the taped rings were directly under the rubber focusing grip, so easy off, easy on.
 If it's the same on your 105/1.8, remove the tape, adjust infinity, and replace the tape.
The nice thing about the Scotch tape lenses is that you can go back and re-adjust infinity without taking it to a shop.
« Reply #2 on: March 13, 2016, 16:31:15 »
,,,, found that it was focusing in just a bit before the lenses infinity hard stop, hitting the infinity hard stop threw it out of focus somewhat.....
How much is a bit on the scale on the lens,,,
ED lenses focus past infinity so does many other lenses,,,
« Reply #3 on: March 13, 2016, 16:44:41 »
i was told that this focusing pas infinity by a bit thing was done on purpose to accommodate glass expansion when the glass is hot under the sun  :o :o :o
you can change that easily by adjusting the numbers and then taping it back  ::)
on series E lenses and many 80's Zoom-Nikkors, it's another story.
« Reply #4 on: March 13, 2016, 16:59:25 »
Yes it is, for ED glass.
« Reply #5 on: March 13, 2016, 18:15:15 »
Ais 105/1.8 doesn't use ED glasses and should have the infinity stop right at the infinity...
simsurace
« Reply #6 on: March 13, 2016, 20:27:44 »
Doesn't non-ED glass also expand?
Simone Carlo Surace
suracephoto.com
« Reply #7 on: March 13, 2016, 21:07:33 »
Not to a point where its a problem.
