Author Topic: The Nikkor AM-ED (APO-Macro) f/5.6 Lens  (Read 12755 times)
Re: The Nikkor AM-ED (APO-Macro) f/5.6 Lens
« Reply #30 on: March 14, 2016, 16:15:55 »
Just returned home and located my 120 AM.
First image shows the lens split with front part incl. the Copal shutter, rear section, BR2 reversal ring, 37-52 step ring (for centering), a T2-M39Leica adapter (distance spacer). Also apparent is that the lens indeed is multicoated (we discussed this aspect earlier in this thread).
Next, put the 37-52 onto the rear end of the shutter with the narrow opening down. This will to the required first approximation center the rear lens. Add the T2-M39 spacer, put the BR2 on top, and stick the rear lens into the opening and screw it home on its threads at the back of the shutter unit. That's it.
This trick works because the rear lens is a trifle wider in diameter than the free opening on the F-mount bayonet. Were the lens to be mounted directly on an F-mount camera, this of course wouldn't work as the rear element would jam in the camera throat. However, due to the design of the 120AM, this mounting approach is impossible as the lens needs much longer extension just in order to focus to infinity (for which, might I add, it is not designed ...). All bellows or extension tubes have the required internal clearance.
Assembly time about 20 sec with practice.
Other solutions are of course feasible, but one uses what is available on the work table for such minor modifications. I have used the lens thus modified for decades. I add a narrow extension with a CPU inside to the bellows to have the correct EXIF data recorded as well.
« Reply #31 on: March 14, 2016, 16:36:08 »
Got it. Did it. It works. Thanks much!!!
« Reply #32 on: March 14, 2016, 16:40:55 »
Just glad to be of any assistance.
simsurace
« Reply #33 on: March 14, 2016, 16:50:29 »
Very elegant solution. You got to love cobbling together a set of seemingly unrelated adapters and using them to construct a custom mounting solution.  8)
Simone Carlo Surace
suracephoto.com
« Reply #34 on: March 14, 2016, 17:37:11 »
The idea is a stretch but the result is elegant!
BR Super!
Mongo
« Reply #35 on: March 15, 2016, 04:10:32 »
thanks for the pictures of this lens. It is the one ! Now Mongo will have to put it to good use.
« Reply #36 on: March 15, 2016, 11:38:33 »
Here is the assembled lens and mount, with a hood to help keep out the stray light. Thanks to nfoto!
« Reply #37 on: March 15, 2016, 16:47:38 »
A question for nfoto:
I have run into the problem with the mount for the AM-ED 120. Now that I have screwed it together as directed, the aperture setting is frozen and won't move. Somehow the tightening restricts it. If I loosed it up, it will work, but then the whole thing is no longer tight. Any suggestions? Thanks.
« Reply #38 on: March 15, 2016, 17:00:41 »
Look underneath the shutter unit. There is a lever that sets the aperture, this connects to a metal plate that needs to be free in order to move the aperture to a new setting. This coupling has become jammed somewhere.
Examine the distance spacer(s) used and arrange them so no jamming occurs. Ensure the 37-52 has its smaller opening directed against the shutter back end.
« Reply #39 on: March 15, 2016, 17:57:02 »
I found the problem. I had the 37-52 upside down, but for a reason. Which was that this is the only way it would work, because the t-Mount is slightly too thick. I have Fotdiox T-Mount to Nik ring, but as mentioned it is just a little too thick. If you have any other ideas os something of that diameter that is a little thinner, that would work.
« Reply #40 on: March 15, 2016, 18:15:41 »
You mentioned the BR2 Ring and I have the BR2A Ring. That must be the problem. I finally found a BR2 Ring (not the A variety) and ordered it. Will that do it?
