Author Topic: Nikkor 10.5mm f/2.8 - 62mm filter threads modified  (Read 22957 times)
toups
  • You ARE NikonGear'23
Re: Nikkor 10.5mm f/2.8 - 62mm filter threads modified
« Reply #45 on: December 27, 2025, 14:47:50 »
So I noticed.   ;)
Thinking that I may use the can to cut a ring and insert it as was done to originally protect the lens.  This should allow room the hood/cap to screw into the modified hood ring pressed onto the lens but still protect the dust seal.  Will investigate more later. and update.
Of course there may not be enough clearance for that.
Not overly concerned but figured I'd post the info as a warning.
« Reply #46 on: December 27, 2025, 18:50:34 »
For the auto focus to work the fit must be frictionless or close to. Otherwise there will be strain on the gears that are not meant to bee.
There is no space for anything between the felt seal and the lens hood tube.
Also the front element group will bee loose to rattle around.
Yes you have raised a warning.
toups
« Reply #47 on: December 27, 2025, 19:12:06 »
Yes looks like I need to add a ring without adding friction.  Need it to be a bit thinner than the existing petal ring in order for the hood/cap male threads to clear whatever ring I may add.  Unfortunately, the press fit is too good (too tight) so won't try to remove the ring on the lens although I would have liked it be a millimeter or two higher.  Thanks for the warnings.  From a quick test with a shim, it was clear there is no room between the lens hood and the felt seal.  I do have the petals on enough of a ring that I could cut a ring from that.
« Reply #48 on: December 29, 2025, 17:51:05 »
A ring cut from the original petal hood would possibly work. A bit tricky to glue though.
toups
« Reply #49 on: December 29, 2025, 18:29:10 »
Yes that is my current plan.  Managed to remove the press fit ring cut from a lens hood.  Have errands to run today but may be able to work on it today or tomorrow.  Erik, thanks for the suggestions. :)
Was debating removing the front element group for the glue step but thinking I don't need to go there.  Trying to do as little harm as possible.
All that being said, from various test shots during the modification, I really like this lens in FX mode!
toups
« Reply #50 on: January 04, 2026, 22:18:24 »
Third attempt to reseal was the charm.  First attempt was to use the existing left over piece from the petal removal.  That would have been fine but I wanted to get too cute to machine it like the final result, however, it was clear that I couldn't make it thin enough for what I wanted.  Second attempt ended up too tight so I started over.  Here is the third attempt.  As will be clear, and is appropriate the the title of this forum, I probably made things much more complicated than they needed to be since I wanted to be able to screw in the lens hood cap and not limit the field of view with the added assemblies.
First I built up a ring using layers of plastic shim stock.  The idea is that the inner ring is the surface while the outer ring matches the lens outer diameter.  There is now room for the hood to screw in between the inner ring and the aluminum ring cut from the 58 mm lens hood (that has a 62 mm filter thread.  After lots of work, the key parts are from left to right, the ring made of layers of plastic shim stock assembled with super glue, the ring to attach to the lens cut from a 58 mm lens hood and the 62 mm lens hood.  Not shown is the metal 67 mm lens cap.
Note the ring fits easily into the 62 mm lens hood that serves as the lens cap.
Now the shim stock ring is put into the the ring that will be press fit onto the lens and the hood cap is screwed on the shim stock ring is pushed until the orange ring is against the hood cap edge.  This positions the black portion of the shim stock ring to be just above the edge of the press fit ring.
Here is the lens with the lens cap including the metal cap after press fitting everything together.
Without the lens cap at far focus and close focus.
Of course this sounds easier than it turned out to be.  First, the orange shim ring was originally much wider than the final version to allow the assembly to be glued together. In the this image are the raw parts.
Next the orange ring was placed in the press fit ring and the smaller black shim was glued to it.  In this image the two larger black shims that form the inner ring have been placed inside the orange/black ring but haven't been slid to the proper position.  Note these are all over length compared to the final assembly.
After some sanding of the orange black ring to square up the surfaces and positioning and gluing the larger black inner ring shims, the ring was sanded until it reached the final 1.75 mm orange ring thickness.  Then the entire assembly was sanded until about 4.25 mm tall.  This was done so that the shim ring sticks just past the end of the press fit ring.  The complicating factor is that I wanted the shim assembly and the press fit assembly to not limit the field of view of the lens but the inner shim ring to cover the entire felt seal ring when the lens is at close focus.  The good news is that this is possible if the shim ring extends to the shoulder of the lens at infinity focus, it will then just completely cover the felt ring at closest focus.  This does not leave a lot of room for error.  Speaking of room for error, I had to sand the inner shim ring a bit so that I ended up with the correct fit where there is some but very little drag due to the felt ring touching the inner shim ring.  This was in spite of test fitting all the shim stock pieces before assembly.  Somehow after gluing, it ended up a bit too small so some sanding was needed.
All in all, I happy with the way this turned out; it just turned out to be a longer project than originally anticipated.  Of course a lot of the difficulty was self inflicted.
P.S. In spite of good hopes for the Bircfhwood Casey Aluminum Black Metal Finish, it really didn't leave much of a permanent finish for me.
