Author Topic: Voigtlander 125mm APO-Lanthar VS. & El Nikor APO 105mm  (Read 2626 times)
« on: March 05, 2016, 00:02:17 »
Shots taken with two lens, same light, Nikon D810, Zerene Stacker, within minutes of one another. A little post development, as usual, but look at how different they look, in terms of color, etc.
The first is El Nikor APO 105mm f/5.6 and the second is Voigtlander 125mm APO-Lanthar f/2.5
Interesting.
Re: Voigtlander 125mm APO-Lanthar VS. & El Nikor APO 105mm
« Reply #1 on: March 05, 2016, 00:41:38 »
There is an appreciable shift in hue indeed. I would normally not consider the APO-Lanthar to be a "cold" lens so that might imply the EL-Nikkor is "warm" ?? Assuming of course the light regime was unaltered between the captures.
« Reply #2 on: March 05, 2016, 01:18:35 »
It was all the same, so the El Nikkor is warmer. I will do some more comparisons of the two. Both are great, but at least in these two shots taken minutes apart, they are very different.
« Reply #3 on: March 05, 2016, 03:59:04 »
hmm, how was the white balance done? With lenses having obviously different transmissions, especially in the blue wavelength, I would have done an individual white balance upfront.
« Reply #4 on: March 05, 2016, 05:40:32 »
I do some more tomorrow with careful white balance.
Almass
« Reply #5 on: March 05, 2016, 06:26:16 »
....and if you can compensate for the difference of 20mm so both pics have same comp  8)
« Reply #6 on: March 05, 2016, 18:58:15 »
you surely meant magnification ;-)
« Reply #7 on: March 05, 2016, 19:00:15 »
My interpretation was the images should cover the same field. This of course will imply different perspectives as the focal lengths are not identical. Magnifications ought to be pretty similar, though.
