Author Topic: B&W in camera  (Read 6160 times)
B&W in camera
« on: February 27, 2016, 23:56:17 »
I like how the d750 renders images in black and white. The following are sooc after conversion from raw file in camera. Any ideas how to get the same in the computer?
Re: B&W in camera
« Reply #1 on: February 28, 2016, 00:02:49 »
In comparison, this is what I get when trying to duplicate the same process in lightroom:
Re: B&W in camera
« Reply #2 on: February 28, 2016, 00:06:53 »
Paco, the lighting conditions between these batches are too different to compare the characters of these two B&W conversions.  The in-camera shots are all nice snaps, and LR versions are very artistic.
Re: B&W in camera
« Reply #3 on: February 28, 2016, 00:30:58 »
I see... let me try one conversion from the first batch in Lr
Re: B&W in camera
« Reply #4 on: February 28, 2016, 00:34:52 »
Paco, are you sure that there is a difference?
I guess you are going to have to compare two shots of the same subject shot at the same time :)
I am curious to see the results.
Re: B&W in camera
« Reply #5 on: February 28, 2016, 00:39:46 »
There you go: first, Lr; second, in camera
Re: B&W in camera
« Reply #6 on: February 28, 2016, 00:43:13 »
I´m sure there is a way to adjust contrast, shadows, exposure, sharpening, noise...etc to get closer and closer but it is a lot of work. I do have several presets in Lr trying to emulate this. Just asking if there is a way to do the same and be done with it.
Re: B&W in camera
« Reply #7 on: February 28, 2016, 03:31:55 »
Even on my 13" TN laptop screen, I can see that these two "matched" versions aren't matched for density.
I have no doubt that you will be able to create a Lightroom user preset that gives you a satisfying look.
charlie
Re: B&W in camera
« Reply #8 on: February 28, 2016, 07:59:00 »
I've never found a one size fits all conversion for B&W. Different skin tones and lighting require different approaches to conversion. That said I do like the conversions straight out of your camera. The deepest shadows are inky black with very little highlights in them yet the midtone shadow areas on their faces maintain a good amount of detail and don't get to dark. Applying curve adjustments to your lightroom version is easy to get the midtones and highlights similar to the in camera version but difficult to make the blacks reach the same level without pulling the midtones down to dark.
Do you use the B&W mix color panel for conversion in Lightroom, or the saturation slider?
Maybe the quickest way would be to use nikon software for your B&W  conversions. I suspect it would give the same result as the camera.
Re: B&W in camera
« Reply #9 on: February 28, 2016, 08:24:39 »
Paco, I really like your PP of the second batch.  The highlights make nice contours of the subjects and create interesting light paintings.
That said, I would have to say that the SOOC B&W is more appealing to me than the LR process from the same frame.  The former is more contrasty in a pleasing way, and the facial elements are better rendered.
My friend pro photog once said that the JPEG files created in the modern digital cameras are so good that it is hard to beat them by processing RAW files.
Re: B&W in camera
« Reply #10 on: February 28, 2016, 08:35:46 »
Perhaps off topic, but it does speak about jpgs, Nikon software, Charlie's and Akira's words.
Whenever I shoot people/portraits I NEVER process the files in any other software but Nikon ViewNX2.
Whenever I open the RAW file in Adobe PS or in PhotoNinja I lose the skin colors in such a way that I cannot process the RAW file to achieve what freeware does automatically.
So Paco, I am not surprised that the BW in camera conversion is better than Adobe's one.
I am deeply sorry that there isn't appropriate Nikon software, because they for sure know how the colors and contrasts work in their cameras.
BW
    • Børge Wahl-Photography
Re: B&W in camera
« Reply #11 on: February 28, 2016, 08:41:04 »
The mono SOOC look good to me. I have also made a few presets in Nikon Picture Control for different contrast (colorfilters and/or curves, levels) and effects. They work well as long as I use Raw+jpeg so that I can go back and process them in Nik/Google silver efex if I want to.
Re: B&W in camera
« Reply #12 on: February 28, 2016, 10:53:44 »
The shots in the opening post touch me, esp. the first one is an award winner in every respect. I feel your work in black and white always appeals to me more that your work in color. I even carry some of you shots on my phone to have a look at them sometimes, because I adore them so. Thank you for being an inspiration, Paco!
Re: B&W in camera
« Reply #13 on: February 28, 2016, 10:57:45 »
Same for my Sony, when I was using the Voigtlander 35/1.2 the camera and viewfinder were set to B&W with yellow focus peaking to improve manual focussing but quickly discovered the Sony does better B&W's than I can do in post for most images.
Only with a lot of tinkering in Capture One I could beat it but often failed to do so, partly due to my unfamiliarity with C1.
Mongo
Re: B&W in camera
« Reply #14 on: February 28, 2016, 11:30:54 »
that camera is producing some excellent crisp dense and contrasty B&W images. Mongo agrees with you that it would not be an easy task to get as good results in PP. Even with the use of specialised PP software like Silver Efex etc, it would not be as easy as pressing your shutter button. Even if the result could be duplicated in PP, it would take about 20 mins to a half hour per frame to achieve, if possible. Mongo has had reasonable results but starting with a colour image. There seems to be a lot more adjustment on the conversion to B&W than starting off with a B&W image. At least, that has been Mongo's experience.
Paco, you are on a winner with that camera and you may find it is not possible to get that result without a big effort out of camera. So, the answer to your question is, "probably not".
As a matter of interest, can you tell us the B&W setting on your D750 that give you these results ?? would love to duplicate them in Mongo's cameras if at all possible (unless this is purely a D750 thing)
