Author Topic: Nye Optical f1.4 / 150mm UV-VIS-IR mirror lens  (Read 12322 times)
Ron Scubadiver
Re: Nye Optical f1.4 / 150mm UV-VIS-IR mirror lens
« Reply #15 on: February 18, 2016, 03:42:21 »
It seemed at one time mirror lenses were everywhere, then they nearly disappeared.
« Reply #16 on: February 18, 2016, 04:45:53 »
1) to form a very stable substrate, regarding very low thermal expansion, for both mirrors
2) to form a very hard and resistant, yet very transparent (UV-IR) overcoating for thr aluminum first surface mirrors
Klaus, thanks for further info on the quartz material.  Apparently this mirror lens would not be used under the temperature of 700-1200 degree, the character of the low thermal expansion should be reliable enough for the purpose.  :)
« Reply #17 on: February 24, 2016, 18:02:55 »
That's not the point Akira: it is about thermal changes of the mirror which leads to variations in focal length(s) of the two mirrors and on very large mirrors, aöso distortions, so if you use it at room temparatures and you take it outside at say zero degrees, this change in temparature may lead to that.
« Reply #18 on: February 24, 2016, 19:53:36 »
You mean, the quartz is more stable than the conventional optical glass in the environmental temperature changes?  I'm well aware that the ED or fluoride glasses are very much affected by the temperature changes, which is why the lenses that uses ED glasses are made to focus past infinity to compensate for that.
« Reply #19 on: February 25, 2016, 18:17:45 »
Yes, exactly Akira!
« Reply #20 on: February 25, 2016, 19:59:05 »
Yes, exactly Akira!
Thanks!  Now it is clear!
Alaun
« Reply #21 on: February 25, 2016, 23:19:28 »
Klaus, the thermal expansion coefficient of quartz (crystal) is more than 10 times lager than that of quartz glass.
Wer-      Dro-
      ner         ste
« Reply #22 on: February 25, 2016, 23:39:11 »
Danke. Ich liebe solche Beiträge!
Thanks. I love this kind of Intervention.
« Reply #23 on: February 26, 2016, 04:55:38 »
Hmm...so, what's the purpose of using real quartz?
« Reply #24 on: February 26, 2016, 06:34:03 »
When do we get to see the images?1?   :o
« Reply #25 on: February 29, 2016, 18:07:02 »
When I'm back in Germany  ;)
bikersgold
« Reply #26 on: March 12, 2016, 06:37:48 »
What is one of these lenses worth?
« Reply #27 on: March 12, 2016, 11:45:18 »
Why, have one for sale??
