Author Topic: The Close-Up Face of the Noct Nikkor  (Read 9845 times)
Re: The Close-Up Face of the Noct Nikkor
« Reply #15 on: February 17, 2016, 20:47:08 »
I also like the results very much, moving from the technical immaculate deep stacks to the more artful shallow stacks. Beautiful.
I couldn't say better ! ;D
These images are really beautiful, poetic. Just the result of both great expertise and a very special lens.
Cheers, Francis.
JJChan
  • JJ Chan
« Reply #16 on: February 17, 2016, 23:10:39 »
Unique and beautiful. Not many people can do this sort of work - thank you
JJ
« Reply #17 on: February 18, 2016, 19:52:32 »
My first-take experiments with the Nikon Noct have reached a turning point. I have more to do, but it will be outside when spring comes. My take-away at this time is that, for my kind of close-up work, I will use the Noct wide open or stopped down a bit, either in a single shot or stacked lightly. If stacked, perhaps a shot wide-open for background, and then one or two inscapes, tightly stacked, painting focus on one or a few areas that I want in focus. And because of the fact that this lens is very sharp in the center, but rolls off quickly, I find that it takes extension well, either the K1-Ring (5.8mm) or larger, like the PK-12 (14mm), and this is often needed for close-up work.
This is not a walk-around lens for me, but a specialized lens to add to the series of lenses with “character” or a unique draw that I have assembled. It is very expensive ($3K), but worth the money in that it will serve well for years to come. It really is a wonderful and unique lens, as I had heard all these years. The recent Nikon replacement, as I study the specs will not be the same, in that there is a stronger difference in resolution in the center for the original Noct, and the new lens has better resolution at the edge, but I would rather have the greater roll-off at the edges that the original Noct provides. The new version probably is not something I need.
So, I will continue to experiment with this lens and update here if I have other insights into its use.
This photo taken with the Noct, the D810, the PK-12 extension, and Zerene Stacker.
« Reply #18 on: February 18, 2016, 23:54:08 »
There is a tenderness towards nature in your shots .. love?
« Reply #19 on: February 19, 2016, 00:01:38 »
Love of nature, for sure.
« Reply #20 on: February 25, 2016, 18:18:35 »
Amazing images Michael, it really shows how you both get used to each other!
« Reply #21 on: February 25, 2016, 19:14:12 »
I continue to experiment with the Noct Nikkor on the D810 for close-up work. Can’t say that I have had any more break-throughs, but I am getting a better grasp on what the lens can do for my kind of work. Here are three done with the Nikon D810, stacker with Zerene Stacker. The lens does have a use for close-ups, a great draw, and a look all its own.
« Reply #22 on: February 25, 2016, 20:55:02 »
wonderful colors, great micro constrast and fine rendering of structures - and a good BG bokeh!
elsid
« Reply #23 on: February 25, 2016, 22:24:43 »
Michael, You have perfected your craft. Looking at your pictures makes me feel I am reading very lyric poems.
John Koerner
« Reply #24 on: March 26, 2016, 20:46:57 »
According to this webpage, others, there are actually two versions of the Noct Nikkor 58mm f/1.2 (an Ai and an AiS).
The Ai is a 7-blade lens with a 230° focus throw, while the AiS is a 9-blade lens with only a 140° focus throw.
The Ai is also the elder, and also slightly-heavier, version.
Curious which version is considered superior to the other ...
Jack
« Reply #25 on: March 26, 2016, 21:52:45 »
I own both (AI, AIS) and the difference is less than people imagine.
John Koerner
« Reply #26 on: March 26, 2016, 21:59:47 »
If someone held the proverbial gun to your head, and forced you to keep one, while parting with the other ...
Which would you keep; with which would you part :D
« Reply #27 on: March 26, 2016, 22:26:11 »
I'd keep both. The Noct is on the list of lenses for which I need to have redundancy and backup items.  Others are CV 125/2.5 APO, UV-Nikkor 105, 200/2, 300/2.8, etc.
John Koerner
« Reply #28 on: March 26, 2016, 22:42:49 »
In your original response, you said, "The difference is less than people imagine," which implies there is a qualitative difference (even if negligible).
Do you care to expound on this difference?
« Reply #29 on: March 26, 2016, 22:54:48 »
Apparently there is a slightly less field curvature in the AIS. Do note the Noct is not a flat-field design any way.
Bokeh might be a tad smoother with the AIS. Wide open no difference of course.
I doubt the differences, although can be shown, have any significant impact on the final outcome.
