Author Topic: [Theme] Show us your self-portraits  (Read 149541 times)
Re: [Theme] Show us your self-portraits
« Reply #165 on: January 17, 2019, 23:35:49 »
John, John, John :)
« Reply #166 on: January 18, 2019, 13:08:03 »
« Reply #167 on: January 18, 2019, 14:44:15 »
Cold weather version of Birna.
(Z6, 50/1.8S)
« Reply #168 on: February 10, 2019, 08:36:00 »
Testing the 'new' Infrared en UV-sensitive Fuji IR Pro camera with the 20mm AF lens
« Reply #169 on: February 10, 2019, 11:33:41 »
Interesting - which Fuji model is this? The 20 Nikkor AF doesn't do UV but should be OK for IR.
(I have the original S3Pro UVIR, plus an S5Pro modified to broad-band usage)
« Reply #170 on: February 10, 2019, 12:09:55 »
This is the Fuji IS Pro which is based on the Fuji S5 Pro (and Nikon D200)
https://en.wikipedia.org/wiki/FinePix_IS_Pro
The advantage is that I know by now how to process the Fuji S5 RAF- raw files ...   And how to handle this 'unique' camera...
But now in the learning-mode  to  create and process IR and UV files...
« Reply #171 on: February 10, 2019, 12:11:46 »
Seriously Wow!
« Reply #172 on: February 10, 2019, 12:18:16 »
Congratulations -- the Fuji S5Pro has plenty of "soul" so likely the IS version has as well :D
You might even pull off the occasional visible-light shot with it when combing a UV/IR cut filter and BG-38 or similar (to restore some of the colour balance).
As it draws on an original D200, it handles most F-mount lenses with ease. You need to trick modern E lenses away from their wide open state if stopping down is required, though.
« Reply #173 on: February 10, 2019, 13:08:50 »
Thanks Fons and Birna.
Thanks for the tips Birna, it needs  exploring a whole new world of filters I guess   ;)   (and step-up-step-down rings)
« Reply #174 on: February 10, 2019, 13:23:22 »
Just ask for tips on which lenses do suit a given purpose.
A very well documented excellent lens for the camera is 35-135mm f/3.5-4.5 Zoom-Nikkor. Either the AIS or AF version can be used. They have 62mm filter threads and fetch comfortably low prices on the second-hand market. Another excellent lens for this camera is the 18-140/3.5-5.6 AFS Nikkor G. The latter takes 67mm filters.
Nikon O56 orange or a 590nm filter makes shooting emulated false-colour IR very easy with these Fuji models.
If there are more questions it is better to open a new thread on the Fuji UV/IR capable cameras?
« Reply #175 on: February 10, 2019, 19:25:06 »
Thanks for the Info.   That might be a good idea.
Zang
« Reply #176 on: February 11, 2019, 02:19:56 »
This is me...
Andrew
« Reply #177 on: February 11, 2019, 10:27:45 »
I love this splash of color in the corner-Canadian colours...
Andrew Iwanowski
« Reply #178 on: February 11, 2019, 11:01:45 »
Yes, lovely shot.
« Reply #179 on: February 11, 2019, 15:54:25 »
This is me...
Wonderful minimalistic image that conveys well enough of the image of Canada for me.
