Author Topic: [Theme]windows  (Read 275362 times)
Lars Hansen
  • Zealand, Denmark
Re: [Theme]windows
« Reply #675 on: April 03, 2021, 13:27:13 »
A solitary window.
Re: [Theme]windows
« Reply #676 on: April 03, 2021, 15:52:16 »
Oleeee
mxbianco
Re: [Theme]windows
« Reply #677 on: April 03, 2021, 20:12:31 »
View from my South window in IR
Nikon D70-IR, Chipped Nikkor-Fisheye 7.5mm/5.6
My self-modded D70-IR (niobate sensor filter replaced by 720nm IR filter) has no LiveView, to use the 7.5mm you have to frame your shots by extrasensory perception.
This is from past archives (April 2019)
N.B. The side window panes are reflections, not real window panes.
Ciao from Massimo
Re: [Theme]windows
« Reply #678 on: April 03, 2021, 21:36:39 »
Ciao from Massimo
Nice one Max :)
Re: [Theme]windows
« Reply #679 on: April 09, 2021, 18:31:53 »
A view into a world of fantasy Massimo.
   This was taken to try to use the 105mm 1.4 on a D2X body. If course it can not control the diaphragm so it is all the way open.
  D2X, 105mm 1.4e
Re: [Theme]windows
« Reply #680 on: April 22, 2021, 19:12:45 »
April 22
shop
Re: [Theme]windows
« Reply #681 on: April 24, 2021, 20:24:13 »
manicure window
Lars Hansen
  • Zealand, Denmark
Re: [Theme]windows
« Reply #682 on: May 02, 2021, 00:01:16 »
Secured and closed.
Lars Hansen
  • Zealand, Denmark
Re: [Theme]windows
« Reply #683 on: May 02, 2021, 00:13:06 »
Surreal, Massimo
Stacked windows and people, Paco - a special burned and hot feeling in the colors
Great layers in #680 Fons
Re: [Theme]windows
« Reply #684 on: May 20, 2021, 16:46:19 »
Thank you Lars.
Grafitti window
Re: [Theme]windows
« Reply #685 on: May 24, 2021, 08:23:41 »
Open Window
Re: [Theme]windows
« Reply #686 on: May 25, 2021, 21:13:19 »
Vases
Re: [Theme]windows
« Reply #687 on: May 27, 2021, 13:23:20 »
Through the window. Single shot
Re: [Theme]windows
« Reply #688 on: June 20, 2021, 12:34:46 »
birds
Re: [Theme]windows
« Reply #689 on: June 21, 2021, 10:57:25 »
Glasshouse
