Author Topic: Need a "new" wide angle for Nikon  (Read 2914 times)
Harald
    • Flickr
« on: January 03, 2016, 19:13:19 »
Hi,
i need your advice: I own a 20mm F3.5 Ai. Works fine, but is not really sharp in the Corners. At F11 it is ok, but then the center performance is "gone". I do not need it very often, but when...
So i need your advice: The 20mm 1.8G is for sure a big improvement, but too expensive for 5-6 times in a year. What about the 20mm 2.8 AF-D? Is it much butter? Or the 18-35G zoom? Any opinion is welcome!
Harry
Some pictures on FLICKR
Re: Need a "new" wide angle for Nikon
« Reply #1 on: January 03, 2016, 19:55:03 »
The 20/2.8 AIS or AF-D will marginally be better. They share the same optical formula. Stopping down to 5.6 is the minimum to get acceptable overall sharpness.
In addition, they flare easily. This is why I bought a 20/3.5 UD, which however needs stopping down to f/8.0.
I'd recommend you to get a 20/1.8. You will probably use it more often!
« Reply #2 on: January 03, 2016, 19:57:38 »
The 18-35 is a versatile alternative and quality is pretty good as I recall.
The 24/1.8 is perhaps the optimal candidate if price is not a deterrent. It is really a good performer.
Harald
    • Flickr
« Reply #3 on: January 03, 2016, 20:30:18 »
Hi,
ok, just a little upgrade, not worth the money. My brother owns the new 20mm 1.8. I try to lend me his copy... A zoom would also be to much: I own a good 35mm.
Harrald
« Reply #4 on: January 03, 2016, 23:38:02 »
OK, he is hooked ... *g*
zuglufttier
« Reply #5 on: January 04, 2016, 11:13:02 »
He might let you have another look at it 8)
Harald
    • Flickr
« Reply #6 on: January 04, 2016, 11:25:44 »
 :-[ Ok, i´ll try it in two weeks. ;)
« Reply #7 on: January 04, 2016, 20:11:37 »
I had an Ais 20/2.8 in my D3 period and while it had pronounced wave distortion, it did give an impression of being "sharp" edge to edge once stopped down a couple of stops.  I haven't used it on the D800.
