Author Topic: Suggestion required for lens for travel  (Read 8588 times)
ravijain
« on: November 26, 2015, 08:39:47 »
Hi,
Thank you all in advance. I am planning to go to Singapore soon and to Sri Lanka thereafter. I have a Nikon 5300 (DX) along with the kit lens 18-55mm and a Nikon 50mm F1.8G. I am confused regarding the next lens to buy between Tokina 11-16mm F2.8 and Nikon 24-120mm F4G.
I mostly plan to use it to shoot around the city in Singapore and along the beaches in Sri Lanka.
Much appreciated.
Mike G
Re: Suggestion required for lens for travel
« Reply #1 on: November 26, 2015, 09:02:53 »
Nikon 24-120mm F4G.
« Reply #2 on: November 26, 2015, 10:27:19 »
If you are a wide angle nut like me, get the Tokina.  Otherwise, the 24-120 will be useful.
ravijain
« Reply #3 on: November 26, 2015, 10:46:09 »
Nikon 24-120mm F4G.
Thank you for the advice. Any specific reasons?
ravijain
« Reply #4 on: November 26, 2015, 10:47:01 »
Wouldn't the options become limited with just a wide-angle?
« Reply #5 on: November 26, 2015, 11:13:14 »
People tend to overemphasise the importance of having a "continuous" range of focal length at their disposal. So they think say 14-24, 24-70, 70-200, 200-400, etc.
In reality this frequently just causes frustration and confusion. If you carry for example two lenses, one wide, another longer by a factor of at least 2X (24 and 50, 35 and 85(105) etc.), you will *never* doubt what lens to use for a given scene setting. It's either the one or the other. No zooming back and forth just to find yourself at the border between two contiguous ranges. You actually can previsualise and make the composition more or less directly in your mind before even lifting the camera.
I could happily travel with just 24 and 85. Or 35 and 105. Were I to do a lot of close-up work, I'd put a dedicated lens for that purpose with me in the basic kit.
« Reply #6 on: November 26, 2015, 11:17:42 »
The 20/1.8G will complement nicely your 50/1.8G.
Those two lenses are great performers and they offer great versatility in a light combo.
Unless you are a pro and you are shooting an event, you don't need a zoom.
However, you should know that my opinion is usually insignificant :)
ravijain
« Reply #7 on: November 26, 2015, 12:41:52 »
I understand from your suggestion that I would be less confused if I carry just 2 primes - one long and one short. Sounds great.
ravijain
« Reply #8 on: November 26, 2015, 12:43:13 »
Would this combo be sufficient for landscape and street photography?
« Reply #9 on: November 26, 2015, 13:37:18 »
I don't see why not?
Mike G
« Reply #10 on: November 26, 2015, 14:07:36 »
Ravijain, the reason for recommending the 24-120mm is that I find it is a great walk around lens, very versatile but not a lightweight!
  • Fairbanks, Alaska
« Reply #11 on: November 26, 2015, 14:28:08 »
My core kit that always comes along on travel and currently used on a D5100 is Nikon 12-24mm f/4, and 105mm f/2.5 AIS.  (If I do not carry the 12-24mm it is replaced with 28mm f/2.8 AIS).
Usually a 55 f/3.5 AI micro (sometimes swapped with a 50mm) comes along. I will also have a hard time not bringing my 10.5mm fisheye...
If I think I will encounter wildlife etc. a 300 f/4 comes along and perhaps more so now with the tiny 300PF.
The manual focus lenses have been chipped for full functionality on the consumer body.
All of these fits in a Thinktank holster 20 with side pocket  (or 10 without the 300mm) and the little  Speedchanger modular case.
(It could look like most of the advice above comes from FX users ?).
In my early days with the D200, I traveled with the lenses I already had, which were  20mm f/2.8 and 55mm f/3.5 (perhaps 200 f4 or 300mm f/4 on top of that).
This combination worked quite well for nature captures, but today I would miss the 105mm f/2.5 AIS.
« Reply #12 on: November 26, 2015, 22:12:47 »
I prefer primes.  The primes are generally faster than zooms and much lighter and smaller (for their speed), which I think is advantageous for travels.
If you don't make large prints, the ability to crop also reduces the need of zooms.  When I went to Germany two years ago for an assignment that included taking pictures, I shot everything with a 16mm/f2.8 and a 50mm/1.8 on two APS-C cameras.
The problem with Nikon APS-C system is that it lacks "reasonable" 14mm or 16mm lenses (f2.8 or faster).
« Reply #13 on: November 27, 2015, 04:06:13 »
I also dont see why not, if you favour wide a bit.
I don't, so I would have gone longer (50 &135) if I were carrying primes. (on Full frame)
oh and if you see how Bjørn travels - He travels with 2 T shirts and 2 tons of gear. Genuine.
Alex Cejka
  • South Ontario, Canada
    • Alex Cejka Photography
« Reply #14 on: November 27, 2015, 06:02:20 »
I agree with Jakov. I have traveled on several trips to Europe equipped like that. I rather travel with light and small stuff (unless on pro assignments - then I drag my f2.8 zooms with me).
However on my last trip earlier this year I broke the pattern and took my 24-85/3.5-4.5 VR on my Df. I found I could use little wider end when shooting architecture but for street photography it was just right as I prefer around 35mm for that.
Beside that I usually take my Ricoh GR with me anyway. That gives me very portable solution whenever needed.
I have shot with my friend's 24-120 and found it pretty decent.
My ideal solution for light travel would be 20, 50 and 105 or 130 ta take with, preferably f1.8 (1.4 is big and heavy).
