Author Topic: Nikon PC-E lenses  (Read 3692 times)
DonMcVee
Nikon PC-E lenses
« on: November 26, 2015, 02:45:19 »
Some time ago Bjorn wrote an article on re-orienting the tilt and shift functions of PC-E lenses. Can anyone tell me where I can find that article?
Re: Nikon PC-E lenses
« Reply #1 on: November 26, 2015, 15:55:08 »
Don't think there ever was such an article. However, I have been in contact with Nikon Nordic and they have provided me with an overview of the parts and labour required for modifying each of the PC/PC-E lenses. I can send that to interested parties.
The 85 PC can be modified by the owner as no parts are required. However, the cabling needs to be redressed and you will run the risk of snapping the flat cable as the fit is really tight.
Thomas Stellwag
« Reply #2 on: November 27, 2015, 16:48:22 »
here is on from Achim Sieger about modifying the 24mm    http://www.achim-sieger.de/en/axis-change-pc-e-nikkor-24mm/
Thomas Stellwag
« Reply #3 on: November 27, 2015, 17:35:35 »
Yes and no. You end up with the controls in an inconvenient placement. Plus a real risk of breaking the delicate flat cables inside. During your attempt of getting the lens split to be ready for a rotating, only high-quality JIS screw drivers should be used or you'll end up damaging the screw heads.
I have the official parts list for the modification of all Nikkor PC/PC-E lenses. The 24 PC-E requires three new parts according to this list.
Jukka L
« Reply #4 on: November 27, 2015, 17:54:43 »
I once wrote about this on the old NG.com a long time ago but did not find the post any longer. The 45 PC-E is the easiest of them to modify, only some new flat cables needed. The 24 PC-E is the next one, it might need one cable more or something similar. And the 85 PC-E is the most difficult. It requires some extra parts also to prevent light leaks. I'm not sure if I remember right but it could need something like 12 parts in the modification. I ended having the 45 mm lens modified. But it was not a good solution for everything. Many times I wished I had not modified it.
The Nikon repair shops have a list of the parts necessary and they can do the modification without damaging the lens. I would not try it myself. (the old 85 PC is a different thing, it is easy to modify, no parts needed). The required parts are the pricey part, and one needs them anyway.
-Jukka-
www.jukrama.fi
Jukka Lehtonen
« Reply #5 on: November 27, 2015, 20:34:28 »
The 85 PC-E requires seven replacement parts. The manual labour is stipulated to 1.5 hours which is the longest labour effort of them all.
Andrew
« Reply #6 on: November 29, 2015, 15:31:13 »
Any chance to get description of parts for modification of 85 lens??
Andrew Iwanowski
« Reply #7 on: November 29, 2015, 16:10:46 »
The relevant part numbers for the 85 PC-E are as follows,
JAA63451-1007M
JAA63451-1106M
JAA63451-301M
JAA63451-300M
JAA63451-139M
JAA63451-148M
JAA63451-158M
Any Nikon repair facility can order these parts for you.
raynger
« Reply #8 on: December 22, 2015, 03:41:25 »
I followed these instructions on my 24mm a couple years ago--it works fine.
