Author Topic: ID this ring!  (Read 10317 times)
Intrepid
  • Rank Amateur
ID this ring!
« on: June 17, 2015, 14:39:35 »
Many years ago, I bought these via Sakamoto-san (these aren't available here) from Japan.  The one on the left is hacked for a purpose the other not so much.
Nikonring by Vivek Iyer, on Flickr
I do not have any use for them at all.
Here is a challenge:
1. What are they?
2. What could possibly make the one on the left more useful?
Answer both and they are yours (reimburse me for shipping)!  :)
Vivek Iyer
Re: ID this ring!
« Reply #1 on: June 17, 2015, 14:57:48 »
Nikon BR-6 for stopping down lenses like G-type
Cleaning it :)
Intrepid
  • Rank Amateur
Re: ID this ring!
« Reply #2 on: June 17, 2015, 15:00:24 »
That was fast!  :)
Vivek Iyer
Re: ID this ring!
« Reply #3 on: June 17, 2015, 15:04:20 »
1: BR-4 and BR-6
2: Repair the broken stop down lever? :)
Intrepid
  • Rank Amateur
Re: ID this ring!
« Reply #4 on: June 17, 2015, 15:05:56 »
1: BR-4 and BR-6
Sorry Bruno.
Erik "cleaned" it  (both BR-6, bought brand new in the box, fwiw).
Vivek Iyer
Re: ID this ring!
« Reply #5 on: June 17, 2015, 15:32:53 »
I'm sure he'll put them to good use :)
The yellow tip on the left one made me think of a BR-4 though.
Bruno
Intrepid
  • Rank Amateur
Re: ID this ring!
« Reply #6 on: June 17, 2015, 15:36:34 »
My apologies, Bruno.
Yes, BR-4 (checked the rim to read the ID)!  :)
Both are BR-4 but one has the yellow plastic tab and the other black plastic tab!
Vivek Iyer
Asle F
  • Hovet, Norway
Re: ID this ring!
« Reply #7 on: June 17, 2015, 16:01:05 »
The difference between BR4 and BR6 is that BR4 has male F-mount and BR6 has 52mm female thread
Re: ID this ring!
« Reply #8 on: June 17, 2015, 16:10:09 »
Plus BR-4 has the overhanging "skirt" that tends to make trouble on AI/AIS-type lenses or modern cameras.
The bayonet mount on the left sample looks to be in a pretty awful state, though. Adding a CPU is just so much more easy using a proper rig for drilling the mounting holes.
Intrepid
  • Rank Amateur
Re: ID this ring!
« Reply #9 on: June 17, 2015, 16:14:45 »
Correct.  The inside of the (male) F mount needed to be ground off to accommodate the wiring flex and it went a bit far.
It made no trouble for me with a D300 and the 14-24/2.8 zoom.
Vivek Iyer
Re: ID this ring!
« Reply #10 on: June 17, 2015, 16:27:33 »
It appears that Bruno Schroder was most correct so they should definitely go to him :)
Nice Quiz Vivek! :) Good idea
Asle F
  • Hovet, Norway
Re: ID this ring!
« Reply #11 on: June 17, 2015, 17:13:55 »
The pipe for the cable release and the stop down lever also makes it trouble to mount on cameras with overhanging prism or big grip. My BR-4 will not mount on FE because of that. The ring to the left has fixed that. I think that is answear to the second question.
Re: ID this ring!
« Reply #12 on: June 17, 2015, 18:01:44 »
Google is your memory bank, rather than your friend.   ;D
http://photo.net/nikon-camera-forum/00BvBX
Re: ID this ring!
« Reply #13 on: June 17, 2015, 22:34:17 »
Thank you Eric. I would certainly welcome the chipped BR-4 and reimburse shipping.
Bruno
Intrepid
  • Rank Amateur
Re: ID this ring!
« Reply #14 on: June 17, 2015, 22:50:35 »
Bruno, Sent you a PM. :)
Vivek Iyer
