Author Topic: [Theme] Night sky shots  (Read 133650 times)
Re: [Theme] Night sky shots
« Reply #60 on: April 30, 2016, 12:37:19 »
Øivind, you never stop amazing me!
The comet looks nice, but I'm more attracted to the beautiful blue dot (the Owl Nebula?)!
« Reply #61 on: April 30, 2016, 12:46:02 »
Thanks, Akira, yes I agree - the Owl Nebula is really cool. It can be found near one of the corners of Big Dipper, but is likely too faint to be seen by eye unless a powerful telescope is used.
« Reply #62 on: April 30, 2016, 15:03:35 »
Øivind, truly amazing!
I am really enjoying these space images of yours!
« Reply #63 on: October 01, 2016, 10:52:54 »
Øivind these just get better and better, ;)
« Reply #64 on: October 01, 2016, 23:34:46 »
Thanks Erik,
The dark season has started again, so I hope to get back into this soon.
« Reply #65 on: October 12, 2016, 04:18:03 »
A nice and clear night, first astrophoto session of the season lasted for > 3 hours of which 2.5 hours were exposures, however the aurora showed up less than half way trough, and something was slipping slightly on the setup (it takes time to get back to the good routine) so that I ended up with only 17 good frames, each a one minute exposure. So why not include the aurora to make it more interesting? The Andromeda Galaxy was high in the sky and an easy object to image with less artificial light pollution:
300mm PF at f/4.5, stack of  17+1 one minute exposures @ ISO 1600.
aerobat
« Reply #66 on: October 12, 2016, 06:51:11 »
Øivind these are superb images with the 300mm PF. I have this lens but never thought about using it for night skies.
Your pictures are very inspiring for this genre of photography.
Daniel Diggelmann
BW
    • Børge Wahl-Photography
« Reply #67 on: October 12, 2016, 06:53:24 »
Brilliant Øyvind! I really enjoy your astro telephoto shots :)
« Reply #68 on: October 12, 2016, 07:33:20 »
This is yet another exquisite and romantic image.  I don't see any aurora effect, though, but I think I'm seeing very faint purple and green flare over the entire image.  Does that comes from the aurora you are talking about?
« Reply #69 on: October 12, 2016, 13:53:57 »
Very nice Aurora Andromeda capture - Truly amazing
« Reply #70 on: October 12, 2016, 14:26:52 »
Fantastic results
« Reply #71 on: October 13, 2016, 07:03:19 »
Thanks for the kind comments all of you.
Akira, when getting the aurora into view with a telephoto lens it is enlarged enough to make a curtain of pretty homogeneous color, mostly green. Also, the  one minute exposure will tend to blur it out. The final image resulted from an additive stack of a single frame that contained the aurora and another image that was the result of a 17 image stack that did not contain the aurora. The single aurora frame was heavily processed to suppress aurora and stars in the right hand part where the aurora was weaker, and strong color noise reduction was applied to this frame to avoid noise in the green part. Normally a single 1 min exposure would not have that sharp distinction between the aurora and the background. Here is the 17-image stack without the aurora:
300mm PF at f/4.5, stack of  17 one minute exposures @ ISO 1600.
This is what the aurora  looked like in a single wide angle frame a bit later, Andromeda is located behind the aurora curtain below the two downward pointing branches at the golden intersection from the right and 1/3 from the bottom, looks lie a blurry star (sorry for the non-interesting foreground, image just meant for documentation):
Somewhat cropped frame at @ 12 mm f/4, 20s, ISO 1600
« Reply #72 on: October 13, 2016, 10:52:11 »
Øivind, simply jaw dropping!
« Reply #73 on: October 13, 2016, 22:51:26 »
Øivind, thank you for taking time for the details.  When I looked at the image in question for the first time, my room was a bit too bright due to the daylight from outside.  When I looked at it at night, I could see the transparent green hue clearly.  I appreciate your decision.
« Reply #74 on: October 14, 2016, 02:14:29 »
This is amazing!
