Author Topic: [Theme] Night sky shots  (Read 146550 times)
Re: [Theme] Night sky shots
« Reply #270 on: November 09, 2021, 23:32:00 »
Thanks for the comment Bruno, and for the tip on comet Leonard. The hope of catching the tail of a comet was what originally inspired me to buy my tracker. I have had lots of fun with it and also captured a number of comets, but none of them had any tails to speak of.
The tracker I have is the iOptron SkyTracker Classic ver. 2 (https://www.ioptron.com/product-p/3302b.htm), which is not produced any longer but might be available on the used market. (The aftercomer, Skytracker Pro probably have about the same accuracy and perhaps a better base, and there is also the more expensive SkyGuider Pro).  It seems to be a bit of a hit and miss how long users can expose with these, as they were probably originally designed for shorter focal lengths than 300mm that I usually use, and there is some variation in tolerances of the parts and how well they are adjusted. It does take some experience to work around imprecisions in the altitude adjustment of the classic version. I also removed an excessive washer from the base to eliminate wobble. Look back in the thread for more information.
What I find important with this tracker is that it allows polar alignment to take place with the camera in position, so it allows small adjustments to polar alignment under ways. It also has a good LED for the polar scope. I highly recommend to adapt a right angle viewfinder for the polar scope if you are at high latitudes like me (hardly use the one I got for the camera's viewfinder any longer after I started using my D500), there are used Nikon versions that can be had on eBay for reasonable amounts. Also, some other trackers come without the base, which can add quite a bit weight if you add a geared head to the package. Here is an image of my setup, probably repeated from earlier in this thread.
« Reply #271 on: November 10, 2021, 12:05:54 »
Beautiful meteor image, Øivind!  I love the way the transitional colors of the trails of the meteors are rendered.
« Reply #272 on: November 10, 2021, 22:41:41 »
Thanks a lot for the detailed info, Øivind. It is very helpful. I would use the 500/5.6 PF which is 700gr heavier than the 300 PF.  Do you think it would work with the extra 700gr?
Thanks
« Reply #273 on: November 11, 2021, 01:26:44 »
A while ago, I bumped into this Kickstarter project by Benro.  A tripod head with the built-in GPS, compass and astromatps:
https://www.kickstarter.com/projects/benropolaris/polaris-smart-electric-tripod-head?ref=6tba32
One of the problem I found in the astrophotography is that you had to place your tripod where you can see the Polaris to align the rotation of the tracker.  But here in Tokyo, you are not guaranteed to see the Polaris from the place you want to shoot, because of the bristling buildings.
A tripod head like this one by Benro can solve the problem.
« Reply #274 on: November 11, 2021, 06:40:25 »
Thanks for the comment Akira. Yes the colors of meteors with their transitions can be beautiful, and that is one of the things that makes it easy to distinguish them from satellite tracks beyond that the latter typically appear in more than one frame. Too bad the second meteor was cut off by the end of the exposure, but I think that one would mostly have displayed just the same warm color as the visible section.
Thanks
I have successfully used my Skytracker with the old AF 300mm f/4 ED, which is about the same weight as the 500/5.6 PF, so I do not think the weight is a problem if you are not at too low latitudes so that the polar alignment is more horizontal. It is important to balance the camera so that the weight is working slightly against the rotation. If it balancing at the tipping point slack in the gears can cause bad tracking. However although I have been able to successfully track with TC-14E added to the 300 PF, I feel that the 420mm focal length is stretching it and can be more of a hit and miss. (There is also the issue of bad seeing around here which often limits resolution.) If you could get hold of a very cheap used Skytracker classic, it would not hurt to try it out though.
I have seen a number of very nice results from the 500/5.6 PF, but then usually on a sturdier more expensive tracker with a very low periodic error, the Fornax LightTrack II  https://fornaxmounts.com/products/lightrack-ii-mount/. It is not quite as compact as the smaller trackers, but still quite portable. It will have the disadvantage that it has to be reset during a session once the range of the arm has been fully utilized. Note that a base or extra tripod head is needed in addition to what is seen in the link.
It is also possible that the more expensive iOptron model above or the StarAdventurer could do, but then with guiding (requiring a computer setup) which will reduce the much larger periodic errors of these trackers.
I believe the tracker listed by Akira would be more oriented toward wide angle use and time lapse panning. For high accuracy one really need a polar aligned tracker, not an alt-azimuth oriented one. Also there is the risk of crowdsourcing. I have seen a number of nice results from the built in Pentax Astrotracer that is also based on GPS orientation, but then based on (limited) sensor shifts instead of moving the whole rig.
« Reply #275 on: November 13, 2021, 23:30:59 »
Thank you for the details of the meteors.  And your assessment for the tracker/tripod head makes sense.
« Reply #276 on: November 08, 2023, 11:35:09 »
Time to get the night sky thread going again: Finally the weather provided a short opening for a deep sky capture, and I used it to capture my first supernova ! I used my 300PF on the ASI678MC astro camera, which gives a quite narrow angle of view. I stacked about one hour total of tracked 30 sec exposures. There was some troublesome auroral activity going on both capture occasions below so I troubled with the colors, which are not optimal.
Supernova explosions are some of the most violent occurrences in the universe. (Earlier in this thread the Veil Nebula is a result of such an explosion.) The star that went supernova May 19, SN 2023ixf is in the Pinwheel Galaxy (M101). The top exposure below was captured 1 month before the event. In the bottom exposure from tonight, the supernova is much less bright than at the peak https://skyandtelescope.org/astronomy-news/bright-supernova-blazes-in-m101-the-pinwheel-galaxy/ , but as a compensation it has now taken on a nice red hue that stands out near the center of the bottom frame. It blows me away to be able to witness such a celestial event using this simple equipment.
« Reply #277 on: November 08, 2023, 12:11:04 »
Your images keep fascinating me, Øivind!
Hope you would allow me to crop the bottom image to make sure what you are talking about: is this red one slightly below the center of my crop?
« Reply #278 on: November 08, 2023, 14:07:34 »
Have any of you in Europe been able to catch any of the Aurora Borealis in the last few days?
I've seen some pretty dramatic shots from Southern UK which until recently has never had many
« Reply #279 on: November 08, 2023, 16:07:24 »
Some parts of Norway, in particular the western districts, have had clear skies and people could enjoy stnning displays. I live in the southeastern part and we have grey clouds blanketing everything. Little or no hopes of a reduction in cloud cover unfortunately.
« Reply #280 on: November 08, 2023, 20:16:44 »
Thanks Akira, you got the supernova correctly identified. In the upper capture (which is slightly rotated) there is only just a hint of a star at that location.
All clouded over during that last auroral event that was in the news, and those reds usually appear at lower latitudes and are overwhelmed by the green here. However there were a couple of exceptions this fall that I will have to come back to.
« Reply #281 on: November 08, 2023, 21:21:59 »
Colin, a famous session drummer Ash Soan posted some amazing red aurora images seen from his studio outside London.  I was surprised that aurora was observed in such a low latitude.  You may want to search him on Facebok.
Øivind, thank you for the confirmation!
« Reply #282 on: November 08, 2023, 21:40:41 »
Check out the space weather aurora gallery for the last few days, https://spaceweathergallery2.com/index.php?title=aurora, lots of those captures. Interestingly a lot of what was seen is not regular aurora, but a variant called SAR that has a different origin.
« Reply #283 on: November 09, 2023, 04:04:41 »
The European Space Agency introduces the first images captured by the Euclid space telescope whose main mission is to look for the evidence of the existence of the dark matter and the dark energy, and whose field of view is 100 times wider than that of the James Webb space telescope.
https://www.youtube.com/watch?v=hHWbe82zM8o
« Reply #284 on: November 09, 2023, 16:06:09 »
See here for a selection of Aurora pictures from Southern UK,
including over Stonehenge
https://www.facebook.com/stonehengedronescapes/
