Author Topic: Samyang Perspective control for Sony FE mount  (Read 2802 times)
The_Traveler
    • lewlortonphoto.com
« on: November 09, 2015, 18:37:14 »
Has anyone used this?
Further, I read that that the Sony mount is virtually impossible to find and that an adapter is required.
I am thinking of trying this lens for a relatively inexpensive excusion into perspective control.
Lew Lorton
The_Traveler
a non-technical shooter
Re: Samyang Perspective control for Sony FE mount
« Reply #1 on: November 09, 2015, 19:06:04 »
Not the best lens out there, but apparently quite useful
http://www.northlight-images.co.uk/reviews/lenses/samyang24ts.html
Be prepared to apply some additional efforts in the processing workflow.
« Reply #2 on: November 09, 2015, 19:27:53 »
I haven't used it, so please ignore if this is not the answer you are expecting.
But, fwiw, the LensRentals.com scrutinized the construction of the lens, which may offer you some thoughts on its extended usage:
http://www.lensrentals.com/blog/2013/05/first-look-rokinon-24mm-f3-5-tilt-shift-part-2
The_Traveler
« Reply #3 on: November 09, 2015, 20:29:51 »
thanks for both responses.
I have sent a message to lensrenatls asking if they have adapepter to fit the canon mount to Sony A.
Lew Lorton
The_Traveler
« Reply #4 on: November 09, 2015, 21:15:38 »
Although you should know, the mount of A7II is "E" mount, not "A".
According to both links, the Samyang 24/3.5 for Canon EF has no electric contact, and its aperture is operated purely mechanically.  So you wouldn't need the intelligent adapters by Metabones or Kipon.  A simple cheap adapter would suffice.
simsurace
« Reply #5 on: November 09, 2015, 22:00:37 »
I have the lens in Nikon mount. It is respectable for the price, but needs to be used well stopped down and does not seem to take rough handling well (see the Lensrentals article cited above). It doesn't have contacts, and thus should be easy to adapt to the Sony. I cannot predict whether the different filter array of the mirrorless cam will make the performance better or worse though.
If you want to know more, please ask.
Simone Carlo Surace
suracephoto.com
« Reply #6 on: November 09, 2015, 22:10:19 »
I have the Nikkor 24/3.5 PC and it does a very respectable job on Df and D800. You can destruct it if you fall over it in the field, but then it'll break your ribs simultaneously  (personal experience ...)
The_Traveler
« Reply #7 on: November 10, 2015, 01:14:21 »
Yes, just a mispeaking on my part, thank you.
Lew Lorton
The_Traveler
The_Traveler
« Reply #8 on: November 10, 2015, 01:15:44 »
Thank you.
If I do get and try, will be certain to ask.
Lew Lorton
The_Traveler
The_Traveler
« Reply #9 on: November 10, 2015, 01:16:37 »
I no longer have any Nikon bodies and am trying hard not to destroy any bodies I do have - camera or my own.
Lew Lorton
The_Traveler
« Reply #10 on: November 10, 2015, 01:26:53 »
Well, accidents do happen. Good to know the lens is sturdily built :D
