Author Topic: [Theme] Show us your best moon (and solar system) images  (Read 354632 times)
knb
« Reply #1050 on: June 03, 2023, 02:29:10 »
Thanks Colin. If I am not mistaken, Birna has a 1200mm f/11. But this was about the fun of it, testing my equipment.
I do not think I will go all in with equipment I do not even have at hand. As you see, I am already outresolved by Nasos, and that's just fine.
Thanks to you too, Nasos. Putting more pixels on the moon give more details, as you certainly have shown here. Pretty hefty setup you have there, and you use it to good results.
And of course, you are right that the TC-E 1.4x and 1.7x can not be combined.
Kjetil Narum Bakken
« Reply #1051 on: June 03, 2023, 08:15:19 »
Excellent result, Nasos! I really like the tones you got and some color nuances subtly showing the geology. I usually find that a saturation boost is needed to show those tones.
That TC modification is the first I do when I get a new TC.  ;D . And yes, only the TC-20E variants have a throat that will accept the protruding front element of the TC-14E variants. I once also tried to include the 2x TC-301 in the stack (required temporarily removing the baffle) but results degraded too much - the aperture becomes so small that diffraction becomes a problem, and it only worked with my AF300 f/4 ED.
Images I have seen of the Z-converters could look like they are not stackable? The 1.4 seems to have an even more protruding front element.
The tracker is not for preventing blurring from the movement of the moon (except during lunar eclipses), the moon is too bright and the movement too slow for that to be a problem. But when exposing a video or multiple images for stacking, it takes so long time that at high magnification, the target will soon be out of the frame before adequate number of frames have been recorded.
« Reply #1052 on: November 04, 2023, 08:53:07 »
Last full moon that appeared considerably larger than normal, I could not resist a stack of the Tycho crater region while waiting for Jupiter to get in position. Light is on the boring flat side at full moons, but seeing at the moment was worth a capture. I can usually fit half of a moon within the frame with my new standard setup (last page), but not so this time. (Larger version may be possible if image is opened in new tab.)
Nasos Kosmas
  • Athens, Greece
« Reply #1053 on: November 04, 2023, 15:38:02 »
Very detailed photo Oivid, well done!
« Reply #1054 on: November 05, 2023, 10:51:33 »
Thanks, Nasos - always fun to see how much 300PF can resolve with a little "magic".  :)
« Reply #1055 on: January 20, 2024, 07:19:53 »
Visible moon during the day
Asle F
  • Hovet, Norway
« Reply #1056 on: February 29, 2024, 21:25:00 »
Just before the moon set behind the mountain:
Månen over Døldebergi by Asle Feten, on Flickr
« Reply #1057 on: February 29, 2024, 22:11:44 »
Very well timed, Asle !
« Reply #1058 on: February 29, 2024, 23:05:09 »
« Reply #1059 on: March 04, 2024, 19:16:53 »
That's really atmospheric Astle!
Lovely result
Asle F
  • Hovet, Norway
« Reply #1060 on: March 06, 2024, 15:50:13 »
Thanks. Glad you like it.
« Reply #1061 on: April 01, 2024, 10:30:42 »
Comet 12P/Pons-Brooks is approaching the sun and becomes harder and harder to image between twilight and the time when it gets to low near the horizon. These were captured March 19 (#1) and March 25 (#2). That last one I just got four 30sec frames at ISO 800 before it started to get behind the trees, but it was before moonrise thus darker and it might have become brighter. The tail was clearly visible in a single frame.  The first one is 37 frames stacked in Sequator over 23 minutes, the movement of the comet causes the core to draw a short line. The second one was stacked in Deep Sky Stacker, both images aligned on the stars. 300mm f/4 PF with f/4.5 front aperture on D500 at ISO 800, 33 s exposures.
« Reply #1062 on: April 01, 2024, 15:02:55 »
Beautiful capture, as always!  The absence of the light pollution from the cities would help out there.  Here in Tokyo, the Tsuchinshan-ATLAS comet in October seems to be a bit more promising.  Thanks for sharing anyway!
Nasos Kosmas
  • Athens, Greece
« Reply #1063 on: April 01, 2024, 18:20:06 »
  Excellent captures Oivid :)
« Reply #1064 on: April 01, 2024, 20:51:11 »
Thanks Akia and Nasos. Unfortunately light pollution is actually pretty bad here, Bortle 7-8, which is red zone on the light pollution maps. It has become worse after the introduction of city LED lights. If one can find a free view towards west-north-west after twilight it i worth a try, but window of time before the 12P/Pans-Brooks sets is getting narrower.
