Author Topic: [Theme] minimalist images  (Read 371736 times)
Re: [Theme] minimalist images
« Reply #1665 on: September 15, 2025, 15:50:51 »
Thank you Fons
Hello, the horizon is a little bit curved, is that distortion, at 200mm?
Yes. It may also have an optical illusion with the dark and light zones that makes it look more than it is.
KarlMera
« Reply #1666 on: September 15, 2025, 17:21:30 »
Reviews say the lens at 200mm has 2% pincushion distortion, very much for an expensive lens.
« Reply #1667 on: September 15, 2025, 19:22:09 »
The image in question has barrel distortion. Or showing the effect caused by Earth not being perfectly flat ....
KarlMera
« Reply #1668 on: September 15, 2025, 19:50:11 »
Are you sure?
« Reply #1669 on: September 15, 2025, 20:28:08 »
Yes, for my eyes at least.Which is all I got :)
« Reply #1670 on: September 16, 2025, 07:14:51 »
I declare that it is the curvature of the Earth.
Jürgen Pfeiffer
  • You ARE NikonGear'23
« Reply #1671 on: September 16, 2025, 09:41:06 »
Hmmmhh...
Jürgen Pfeiffer
KarlMera
« Reply #1672 on: September 16, 2025, 10:22:56 »
« Reply #1673 on: September 16, 2025, 21:55:13 »
I'm still leaning towards the optical illusion with light and shadow. Here, for the sake of argument. two images from the almost exact same vantage point at different times (taken a little earlier than the original post)
The field of view is not nearly big enough to appreciate water curvature?
  Z9, 70-200 2.8 fl
ARTUROARTISTA
  • I don't like ladybugs.
    • APM Pintor
« Reply #1674 on: September 16, 2025, 22:29:44 »
resin
KarlMera
« Reply #1675 on: September 18, 2025, 19:04:45 »
Watercolors
« Reply #1676 on: September 19, 2025, 07:27:01 »
Thomas Stellwag
« Reply #1677 on: September 19, 2025, 14:04:09 »
Thomas Stellwag
ARTUROARTISTA
    • APM Pintor
« Reply #1678 on: September 19, 2025, 17:01:01 »
thanks plutón and Thomas it's cypress resin,
KarlMera
« Reply #1679 on: September 28, 2025, 14:35:26 »
Very simple
