Author Topic: [Theme] b&w's  (Read 449784 times)
Re: [Theme] b&w's
« Reply #855 on: February 24, 2020, 16:36:42 »
Happiness after the issue of shares for financing to purchase their community center.
Re: [Theme] b&w's
« Reply #856 on: February 25, 2020, 08:27:05 »
Men at work .   Sony a7rii/Batis 135 f2.8
Re: [Theme] b&w's
« Reply #857 on: February 25, 2020, 10:01:14 »
That's an instant classic Fons.
PeterN
Re: [Theme] b&w's
« Reply #858 on: February 25, 2020, 10:59:56 »
Some classics indeed!
Peter
Re: [Theme] b&w's
« Reply #859 on: February 25, 2020, 11:33:46 »
Thanks.
Re: [Theme] b&w's
« Reply #860 on: February 27, 2020, 21:17:24 »
Stormy.
Re: [Theme] b&w's
« Reply #861 on: April 04, 2020, 23:24:56 »
Behind the model, photographer in action
  Z6, 28mm 1.4e
Re: [Theme] b&w's
« Reply #862 on: April 05, 2020, 09:46:39 »
Is there any idea of using yellow, orange or red filters when shooting for BW?
You do all that doing post processing of the color raw file?
What if the camera has been BW modified?
Re: [Theme] b&w's
« Reply #863 on: May 16, 2020, 21:50:19 »
To answer the last question: if the camera is modified to be monochrome, it pays to process the RAW in a special converter. For example, Monochrome2DNG, which is the one I use for my NEX-5N Monochrome camera.
Using some kind of filtration to cut down on blue etc. has a long-standing history for film-based b/w. If the camera is not true monochrome, I would not use a filter as this effectively would lower the attainable resolution. Instead, emulate the effect later in post-processing. For a monochrome camera, it makes sense to use a filter to reduce brightness of sky or selectively bring out skin rendition.  I often use a deep yellow, orange, or red filter on my NEX-5N, if not going the whole way into IR with an IR-filter.
Re: [Theme] b&w's
« Reply #864 on: May 16, 2020, 21:54:08 »
Using a B+W 093 IR filter (roughly equivalent to Wratten 87C) makes IR capture more or less monochrome from the get-go.  Thus rendering these files in true b/w later is a small, and logical, next step.
Here is an example using this filter on a Nikkor-T 105mm f/4 lens with my IR-modified Nikon D5300.
Re: [Theme] b&w's
« Reply #865 on: May 17, 2020, 22:20:07 »
Some tiny creatures (converted in B&W)
Re: [Theme] b&w's
« Reply #866 on: May 18, 2020, 10:03:21 »
They are fascinating and nice creatures at that stage of development. Not so pleasant after hatching, though.
Excellent close-up work, by the way.
Re: [Theme] b&w's
« Reply #867 on: May 18, 2020, 10:08:47 »
Intriguing image.  You should train them to keep the social distance, though.   :P
Re: [Theme] b&w's
« Reply #868 on: May 18, 2020, 12:49:42 »
Yes, fascinating. it would be even more fascinating if I could take a footage in video mode as we could see the water moving around their mouth to get food  plankton).
Re: [Theme] b&w's
« Reply #869 on: May 18, 2020, 12:51:00 »
 ;D ;D ;D
