Author Topic: [Theme] b&w's  (Read 392546 times)
Jürgen Pfeiffer
  • You ARE NikonGear'23
Re: [Theme] b&w's
« Reply #1500 on: October 15, 2025, 16:44:25 »
Nikon Zf, Voigtländer 15mm/f4.5
Jürgen Pfeiffer
Re: [Theme] b&w's
« Reply #1501 on: October 15, 2025, 16:56:02 »
Nice one Jürgen
ARTUROARTISTA
  • I don't like ladybugs.
    • APM Pintor
Re: [Theme] b&w's
« Reply #1502 on: October 15, 2025, 17:34:11 »
I like your experiments with the D200 and different objects, they´re all inspiring to look more into details
Thanks Thomas, with the D200 I can shoot black and white photos directly, that's why I like it so much.
Thomas Stellwag
Re: [Theme] b&w's
« Reply #1503 on: October 15, 2025, 17:45:27 »
modern hay rolls, looks good in BW
which version of the CV 15mm did you use?
Thomas Stellwag
Jürgen Pfeiffer
Re: [Theme] b&w's
« Reply #1504 on: October 15, 2025, 17:50:48 »
and nowadays hay rolls look like giant Mozarella cheese...
It's the Super Wide-Heliar 15mm F 4.5 in Nikon Z-mount, a nice compact lens.
Jürgen Pfeiffer
Ann
Re: [Theme] b&w's
« Reply #1505 on: October 15, 2025, 21:17:40 »
Lovely lighting brings out the fine details in those carob leaves Arturo.
I hope that you will make a large print of this photograph.
Re: [Theme] b&w's
« Reply #1506 on: October 16, 2025, 08:29:55 »
A dangerous black Mamba. Beware.
ARTUROARTISTA
    • APM Pintor
Re: [Theme] b&w's
« Reply #1507 on: October 16, 2025, 09:54:00 »
Thanks, Ann. I've never actually made a print of a digital photo. I only have developed copies of 35mm and 6x6mm film. What type of digital printing is best for long-lasting colors?
Best regards.
Re: [Theme] b&w's
« Reply #1508 on: October 16, 2025, 14:03:37 »
Ammonoids dreams.
Re: [Theme] b&w's
« Reply #1509 on: October 16, 2025, 14:30:26 »
Ammonoids dreams.
Very nice combination of the motif and its rendition.
Ann
Re: [Theme] b&w's
« Reply #1510 on: October 16, 2025, 18:17:10 »
Setting up your own printer is quite expensive but you would get enormous enjoyment from printing and enjoying the results of your labours.
If you are only going to make prints occasionally, it is more economical to send the files to one of the many services that will make prints and mail the finished results to you. What you are looking for is a company which uses giclée (inkjet) printers with more than the four basic inks.
Pigment inks offer longer print-life than dye-based inks so choose a company that has that kind of printer if you can.
You need to send them images which have 300 pixels psi (often wrongly called "DPI"!) meaning 300 pixels per sq. inch.
Your local guys probably use metric so that equals approximately 120 pixels per sq. cm..
Hope this helps!
Re: [Theme] b&w's
« Reply #1511 on: October 16, 2025, 18:30:49 »
Ann
Re: [Theme] b&w's
« Reply #1512 on: October 16, 2025, 19:31:03 »
Truly venomous.
The real problem is that once you get bitten by this photography thing, you are hooked for life — and it becomes expensive.
Re: [Theme] b&w's
« Reply #1513 on: October 16, 2025, 22:44:02 »
Thank you Akira, Fons, that day the creative fluids were flowing and with those amazing dancers around, inspiration came easy.
ARTUROARTISTA
    • APM Pintor
Re: [Theme] b&w's
« Reply #1514 on: October 16, 2025, 23:38:03 »
Hope this helps!
Thank you very much, Ann. I'll do my research before printing. Everything you told me is very useful.
