Author Topic: [Theme] Do you have a stitched photo?  (Read 209503 times)
Re: [Theme] Do you have a stitched photo?
« Reply #300 on: August 27, 2017, 08:07:13 »
John there are many possibilities to this technique!
« Reply #301 on: August 27, 2017, 08:13:38 »
Vertical stitch.
« Reply #302 on: August 27, 2017, 10:08:25 »
I'm intrigued by the combination of the elements captured in this frame.  :)
« Reply #303 on: August 27, 2017, 17:42:50 »
"Biblioteca Palafoxiana" an old library that use to be the bishop's library, this was donate to the city with the condition of it being open to the public, today is a museum and books are kept away from public use
5 vertical shots, with the nikon 1 10mm f2.8 lens
the solitaire
« Reply #304 on: September 02, 2017, 00:57:56 »
does this count?
20170901-DSC_7142 by b j, on Flickr
8 photo stitch
Buddy
« Reply #305 on: September 09, 2017, 00:47:32 »
The built-in level displayed on EVF helps eliminate the wasted peripherals.  GH5, 25/1.7.  4-stitch pano.
« Reply #306 on: September 09, 2017, 00:50:03 »
Great cloudscape, Akira.
« Reply #307 on: September 09, 2017, 01:27:23 »
Thanks, Anthohy!
« Reply #308 on: September 12, 2017, 11:17:57 »
Three frames shot with iPhone SE and then stitched in CC2017.
« Reply #309 on: September 12, 2017, 11:20:45 »
who needs more than an Iphone :)
« Reply #310 on: September 12, 2017, 11:47:49 »
I'm too afraid to answer.   :o :o :o
« Reply #311 on: September 12, 2017, 15:47:42 »
Akira, worth of a Sci-fi cover. Don´t underestimate the power of the hands. I have seen many many many images taken with Iphones that are not even close to concept/technique to yours. Great result with the tools are your disposal
« Reply #312 on: September 12, 2017, 15:57:54 »
Wonderful results !
« Reply #313 on: September 12, 2017, 16:25:07 »
Paco, you are too kind.  I was lucky because the lighting was very even, and my iPhone SE exposed the three frames so evenly that Photomerge of CC2017 could stitch them very naturally.
That said, the stitched image was pretty much squeezed sideways due to the perspective distortion caused by the roughly 30mm-equivalent lens of iPhone SE directed upwards.  I had to use "Transform" tool in ACR to reshape the rainbow to the correct half circle.
Armando, Thanks!
« Reply #314 on: September 12, 2017, 17:32:38 »
Akira, that is an amazing rainbow, perfectly positioned.
