Author Topic: [Theme] Lens Flare  (Read 101376 times)
Re: Lens Flare
« Reply #120 on: February 04, 2016, 11:52:56 »
Lovely capture Chip!
Re: Lens Flare
« Reply #121 on: February 04, 2016, 12:39:58 »
IR
_EGL6190 by Erik Gunst Lund, on Flickr
Re: Lens Flare
« Reply #122 on: February 07, 2016, 04:10:17 »
A protection filter is good as a "flare/ghost inducing effect" filter.
Panasonic GX8, Lumix G 25/1.7@f22.
Re: Lens Flare
« Reply #123 on: February 07, 2016, 07:05:54 »
On a general note, terminology is confused because many of the images show 'ghosts' more than they do flare. 'Ghosts' of course being reflections of the actual aperture opening and thus clearly showing its polygon-shaped outline. 'Flare' in contrast is just that - something that appears as more or less clearly defined veiling of the entire or parts of the image. Flare reduces the overall contrast.
The two concepts are extremes at either and of a long axis of reflective artefacts going on inside the lens. So admittedly there are transitions. But at the very least, one should for clarity apply the most suitable designation.
Oh well.
Re: Lens Flare
« Reply #124 on: February 07, 2016, 10:48:27 »
nicely isolated effect, I think it's ghosts, is there a term for the color cast they show?
Re: Lens Flare
« Reply #125 on: February 07, 2016, 10:59:07 »
getting to the edge of back light creates veiling flare, ghosts, and there may be some sensor reflection as well (is that it's own type of flare?)
Re: Lens Flare
« Reply #126 on: February 08, 2016, 15:38:10 »
So this is flare...
Re: Lens Flare
« Reply #127 on: February 08, 2016, 15:41:35 »
Paco, a lot of other things come to mind but flare  :)
Re: Lens Flare
« Reply #128 on: February 08, 2016, 15:52:30 »
So this is flare...
Amongst other image-contributing factors, yes.
Re: Lens Flare
« Reply #129 on: February 08, 2016, 16:23:04 »
Oh well.
Bjørn, so far as I understand correctly, my latest image contains ghosts accompanied by their own flare.  That's why I referred to them as "ghost/flare".
Paco, this is fascinating!
Re: Lens Flare
« Reply #130 on: February 11, 2016, 10:45:39 »
flare of the nikkor 50-135/3.5 ais stopped down at f32 shooting into the sun
flare of the pc-nikkor 35/2.8 ais stopped at f32 full upward shift
on Df.
Both lenses have recently been serviced and repaired through the help of a friend
Re: Lens Flare
« Reply #131 on: February 11, 2016, 15:18:59 »
Ok then. Thanks Jakov and Akira. Work is sometimes hard.
Re: Lens Flare
« Reply #132 on: February 11, 2016, 16:05:40 »
Your Df is getting dirty, Fons ...
stenrasmussen
Re: Lens Flare
« Reply #133 on: February 11, 2016, 17:43:07 »
Just like mine. I think I've swabbed the sensor once since I got D f...
Re: Lens Flare
« Reply #134 on: February 11, 2016, 21:18:07 »
Certainly f32 is challenge for any sensor, not to forget i change lenses quite frequently, btw it needs a thorough cleaning  :)
