Author Topic: LENS CHALLENGE  (Read 9789 times)
LENS CHALLENGE
« on: September 11, 2015, 16:24:26 »
The work of Solvin Zankle has been discussed on photography forums almost as much as the thread “Is Kenny G Jazz?”  No one seems to know. Here is some of his work.
http://solvinzankl.photoshelter.com/gallery/Wide-view-macro/G0000Xj5NXkE1giM
I would like to ask here whether any of our very talented lensmen have any ideas of what kind of lens-setup it would take to get this close and still have infinity sharp or sharp enough.
Your thoughts please?
simsurace
Re: LENS CHALLENGE
« Reply #1 on: September 11, 2015, 17:23:30 »
A borescope?
Simone Carlo Surace
suracephoto.com
Re: LENS CHALLENGE
« Reply #2 on: September 11, 2015, 17:35:44 »
A borescope?
Can you point to a borescope that might work?.
Peter Forsell
  • A Cunning Linguist
Re: LENS CHALLENGE
« Reply #3 on: September 11, 2015, 19:36:51 »
I don't think a borescope was needed, although if the snakes were venomous I'd prefer one... a long one.
All of the images were shot with a very wide angle lens and many of them show the telltale signs of a fisheye. Some fisheyes focus very close without help and a short extension ring could be used to focus even closer.
Nice images.
Re: LENS CHALLENGE
« Reply #4 on: September 11, 2015, 19:45:50 »
I question this. I have both Nikon 16mm rectangular fisheye lenses (and a circular fisheye) and I have no extension that will work that will also give me the infinity (or near to it) that is in some of those photos. SO, it may be a special fisheye with no extension. Any other ideas?
Peter Forsell
Re: LENS CHALLENGE
« Reply #5 on: September 11, 2015, 19:56:34 »
In the front page provided by your link he explains, that he modified a wide angle lens. This could mean inserting some kind of custom extension to the mount.
Is it given he is shooting Nikon? I could not find info about his gear by glancing. And while his camera could be a Nikon, the modified lens can be of any make.
I still strongly feel many of the shots were taken with a fisheye. I can be wrong though.
Re: LENS CHALLENGE
« Reply #6 on: September 11, 2015, 20:08:27 »
I understand. It could be a fisheye with a specially-made extension. The smallest extension Nikon offers is the K-1 Ring, which is 5.8mm. As you know, wide-angle lenses and especially fisheyes take very, very little extension without blowing up. I am looking into getting a tinnier extension made. And he may have stacked the image, as it suggest on that opening page.
But I believe that is what happens. The only other thing, which is very impractical, would be to do all this in post, based on merging a stacked image with a background image, but I see no signs of that in the photos I have seen.  Since his backgrounds are blurry, I believe it is a really small extension on something like the Nikon 16mm fisheye. Maybe nfoto will have some ideas.
Re: LENS CHALLENGE
« Reply #7 on: September 11, 2015, 20:12:47 »
 On some of the photos it is obvious that a fish-eye was used, but not on all of them.
I am not even sure whether he used an extension ring at all since fish-eyes and super wide angles have a rather short minimal focussing distance?
Re: LENS CHALLENGE
« Reply #8 on: September 11, 2015, 21:03:46 »
OK. I ran out in the back yard and took a quick photo. Imagine there is a big bug in the flower in the lower-right corner. That’s the setup. Now, what I would like is to be a little closer. As it is, I am “all in” with the Nikon 16mm Fisheye. What would do that is a very slim extension, smaller than the slimmest I have, which is the K-1 Ring at 5.8mm.
Next, I would probably want to carefully stack the photo, at least the flower part. The focus ring on the Nikko 16mm Fisheye is almost nothing, so I might want to put the camera/lens on a fine focus-rail and have a more fine focus, if that is possible.
I think that would solve the problem, (1) a little closer and (2) a stacked image.
Thoughts?
One problem is that with auto-focus lenses like the Nikkon 16mm Fisheye, I am not sure you can add a K-Ring, because of messing with the connections. Can someone clarify that for me and what would I have to do to an extension to get around that?
Re: LENS CHALLENGE
« Reply #9 on: September 11, 2015, 21:48:24 »
I think the effective focal length here is very short, but the angle of view not necessary super wide. One notes that the perspective is steep (implying a short focal length and short distance), however, this is not true 'macro' merely close-ups. So perhaps a suitable cine (or similar) lens around 4 mm focal length in conjunction with a relay lens could do the trick.
Re: LENS CHALLENGE
« Reply #10 on: September 11, 2015, 22:30:41 »
Wide angle – I learned to rethink when I started to use Large Format optics – my beloved Schneider has a 15cm images circle at infinity and f=11, which is perfectly usable with the D600, if you stack you can use 5.6 or 8.0 on any body.
"Image Circle" in Schneider terms means: "at least 90 lines per mm". If you have a non moving target you get super high res plus potentially any DOF you wish for (as in "painting focus" – I love that trerm)
Re: LENS CHALLENGE
« Reply #11 on: September 11, 2015, 22:36:24 »
How would you approach getting into the ballpark of the kind of photos that Solvin Zankle does. I am not interested in imitating what he does, but I would like to realize some of my own images with that kind of closeness. I am sorry I don't know much about combining lenses, etc. I know that my Nikkor Repro lens is a relay lens. I guess I would need some help here, if you would be kind enough to explain what I need. I have a bunch of lenses, most of them ones you recommended in one way or another.
Re: LENS CHALLENGE
« Reply #12 on: September 11, 2015, 22:37:11 »
The limit is that near focus has to be at least 4*focal length, so if a steep perspective is required, the actual focal length also must be short.
Re: LENS CHALLENGE
« Reply #13 on: September 11, 2015, 22:43:21 »
To add another uninitiated comment: These photos push expectation ove a certain limit. I understand perfectly well why your interest has been awoken
Re: LENS CHALLENGE
« Reply #14 on: September 11, 2015, 22:45:38 »
A modern version of Lennart Nilsson, the Swedish photographer who pioneered the ultra-steep perspective.
