Author Topic: [Theme] Df (D750)+ Rodenstock Heligon 100mm f/1.6  (Read 148431 times)
Re: Df + Rodenstock Heligon 100mm f/1.6
« Reply #90 on: October 04, 2015, 20:51:34 »
Cool shot Sten. You must have been about 1.2 m away from the van  ;)
« Reply #91 on: October 05, 2015, 10:53:47 »
Have a productive and a stressful free week NikonGear.
« Reply #92 on: October 06, 2015, 09:25:34 »
A complementing duo this time: open and close
And a very good morning  8)
Andrew
« Reply #93 on: October 06, 2015, 10:22:54 »
Jakov-you know very well your's tools!
Andrew Iwanowski
« Reply #94 on: October 06, 2015, 10:25:05 »
There is no doubt the Rodenstock 100 mm f/1.6 is "photogenic". The combination of relatively long focal length and fast speed leads to clearly defined planes of focused vs. out-of-focus detail, that make the image 'pop'. Still the lens has to be used deliberately to gain these results, they aren't immediately available just attaching the lens to a camera and poking it around in a random fashion. Also adding to its success is, in my opinion, the lack of an adjustable aperture, and the need to add or remove extension to change its magnification of detail (or if you prefer, change its focused distance).
Many of these amiable features are available in other industrial lenses as well. However, the 100/1.6 has the advantage of a quite long register (distance from rear element to film plane) as far as this kind of lens goes. Thus, one is not forced into using it only for extreme close-ups, a fact that furthers adds to its versatility.
« Reply #95 on: October 06, 2015, 10:25:40 »
Thank you Andrew!
You know your tools very well too :)
Andrew
« Reply #96 on: October 07, 2015, 08:53:54 »
Jakov, are you talking about inches? Again??
Andrew Iwanowski
« Reply #97 on: October 07, 2015, 09:19:18 »
A bit of urban nature  ;)
« Reply #98 on: October 07, 2015, 09:39:27 »
Andrew I only talk in centimeters ;)
« Reply #99 on: October 07, 2015, 09:45:02 »
Smooth and harmonious midweek NikonGear :)
Andrew
« Reply #100 on: October 07, 2015, 11:13:24 »
OK, let's be metric....
Andrew Iwanowski
Andrew
« Reply #101 on: October 07, 2015, 21:31:30 »
I have to apologize-I still don't have Df body... Some with D750 and Heligon, some with helicoid about 1and1/2 inches long, this mean 3.4 cm-it's correct?
Andrew Iwanowski
« Reply #102 on: October 07, 2015, 22:13:42 »
Andrew, these are beautiful. No matter the body used  ;)
« Reply #103 on: October 07, 2015, 22:17:25 »
Yes, lovely stuff, Andrew  ;)
Andrew
« Reply #104 on: October 08, 2015, 10:08:24 »
Thanx Guys!
Happy that you approve my choice of the Body, Jakov!!
Andrew Iwanowski
