Author Topic: Wildlife is the heart of my photographic addiction  (Read 4927 times)
Ian stuart Forsyth
« on: June 15, 2015, 05:55:21 »
Common Snipe shot with the D800 200-400 F4 II and 1.7tc
Re: Wildlife is the heart of my photographic addiction
« Reply #1 on: June 15, 2015, 07:19:35 »
The green leaves that contour the body are a nice addition.
Lance B
« Reply #2 on: June 18, 2015, 08:59:25 »
Very nice, Ian. Love the pose, great detail and it is best to click on the image and see it large for full impact.
Ian stuart Forsyth
« Reply #3 on: June 19, 2015, 05:36:26 »
Thank you both ;)
Ian stuart Forsyth
« Reply #4 on: June 19, 2015, 05:42:15 »
Shot with the D800 and the 200-400
« Reply #5 on: June 19, 2015, 11:44:45 »
These are very nice, but the watermark is rather intrusive.
« Reply #6 on: June 20, 2015, 00:35:56 »
Hi Ian, how is that 200-400VRII & 1.7TC combination working for you?
I used to own the MKI version of that lens and really didn't like with TC's, curious if the MKII is different in that regard.
Ian stuart Forsyth
« Reply #7 on: June 22, 2015, 08:07:13 »
I find you have to pay close attention to AF correction with regard to using the mark II with the tc, I find that the 200-400 has a shift around the 20m distance where I need to use a different focus correction than I would need to use closer than 20m, using the 1.7 tc only magnifies this problem.
Once I correct for this I find the 200-400 handles the TC rather well
Bellow the 200-400 II with the 1.7 wide open F6.7
 I just picked up the 1.4 III and I find it better than the 1.7 and AF is hardly hampered see my next post
Ian stuart Forsyth
« Reply #8 on: June 22, 2015, 08:09:32 »
Some photos taken with the D800 200-400 II and the new 1.4 III
Ian stuart Forsyth
« Reply #9 on: July 01, 2015, 05:01:49 »
Another BIF series
One of these days I will nail a full set as they enter the water
Andrew
« Reply #10 on: July 01, 2015, 10:57:26 »
You are the master!
Andrew Iwanowski
« Reply #11 on: July 01, 2015, 11:39:01 »
Very nice captures! The 200-400mm is indeed very nice. But many people has stated strange issues with sharpness and also converters like the ones you mention... There must be something about it :)
Meanwhile, when it works it works :)
Ian stuart Forsyth
« Reply #12 on: July 03, 2015, 08:05:23 »
Ian stuart Forsyth
« Reply #13 on: July 03, 2015, 08:09:07 »
I was not happy with the 1.7 until I found out that with the 200-400 I would see a shift in the focus plane for different subject distances and also when changing the Fstop.
Once I figured this out and apply the correct AF correction for the condition at the time of shooting I found them to work very well on the 200-400
I will also add that the new 1.4 III seems not to have that much of a shift
« Reply #14 on: July 03, 2015, 12:08:12 »
Thanks for clarification Ian, I remember the Mark I having the same issue of becoming soft at long range. Not sure though if the word was out back then (2009) that it was caused by focus shifts but that would explain a lot about its performance quirks with and without TC's.
I usually shot within 20 meters anyway where it performed perfectly and instead of using TC's I switched between a D700 and D300 if less or more focal length was needed.
Great images btw :)
