Author Topic: Vacuumcleaners  (Read 2477 times)
Vacuumcleaners
« on: August 21, 2015, 00:27:20 »
Not used late in the evening...
Re: Vacuumcleaners
« Reply #1 on: August 21, 2015, 09:45:51 »
Nice capture, I like the subject, but I would go back and try to do it more graphical and see if the back ground could be excluded somehow....
Re: Vacuumcleaners
« Reply #2 on: August 21, 2015, 10:36:35 »
I agree with Erik. Lots of potential with editing
Re: Vacuumcleaners
« Reply #3 on: August 21, 2015, 11:42:07 »
I like to see a clean pattern repetition here too. Play with the angle
and the depth.
Re: Vacuumcleaners
« Reply #4 on: August 21, 2015, 11:53:02 »
Yes consider both a re-shoot and different post processing. If you feel like it!!!  ;)
Re: Vacuumcleaners
« Reply #5 on: August 21, 2015, 20:36:27 »
Erik, Elsa and Frank  thank you all for your tips and advise.   I just stumbled across the (new) cleaners  with a 50mm 1.8  only, and there was not much space to navigate 'cause of parked cars.
I shall look into the different post-processing and a reshoot.
This was the original RAW by the way.
Re: Vacuumcleaners
« Reply #6 on: August 21, 2015, 20:47:56 »
Sure do a reshoot maybe low angle and as wide angle fl as possible:)
Have fun!
Re: Vacuumcleaners
« Reply #7 on: August 21, 2015, 20:50:46 »
Thanks Erik. That's always fun, of course  ;)
Re: Vacuumcleaners
« Reply #8 on: September 18, 2015, 09:07:27 »
A reshoot with Nikkor AF-S F/2.8  17-35  at 17mm
Not really satisfied yet, but it's in progress   ;)
Re: Vacuumcleaners
« Reply #9 on: September 18, 2015, 09:45:32 »
I feel that this project is on a good way. The repetition of forms and the color contrast really make the picture.
Of course the light is really bad anmd I feel yozu should be farther away to make for a flatter field. Is it possible to shoot this at 90mm for perfect geometry?
And maybe do an HDR to retain all detail in the high lights?
