Author Topic: Nikon 105 F2 Portrait Lens  (Read 3022 times)
Grahame Hamblin
« on: August 18, 2015, 08:08:46 »
Hi i have been offered this lens Nikon 105 F2 Portrait Lens is it worth having and what sort of value would it have. It is in reasonable condition.
Thanks Grahame
Re: Nikon 105 F2 Portrait Lens
« Reply #1 on: August 18, 2015, 09:54:57 »
You mean the AF 105 mm f/2 Nikkor DC? This is a specialised lens with a unique 'DC' (= defocusing control) that allows the user to change spherical aberration and thereby change the appearance of the zone of sharpness in front of and behind the plane of focus. This feature can be very useful, but difficult to master. Be warned that its AF is by 'screw driver' so is quite slow and noisy compared to the AFS kind. AF is also inconsistent due to the DC as there is, at certain DC settings, no true optimum focus in planes perpendicular to each other on the optical axis. Manual focusing is pretty smooth and many myself included prefer that over AF. It has a rear-focusing variation of the internal focusing (IF) principle so length is constant during focusing. There is the vulnerable A/M ring that is prone to breaking. Don't use that control; set the lens to 'M' and tape the rotating ring into position of seal it with a few judiciously placed drops of epoxy. Repair to a broken A/M ring is very expensive and you actually risk that the lens breaks into two (this happened with my sample).
The lens hood is built-in and for once can be locked in extended position, but beware the threads are very fine and can easily jam, cross-thread, or bind, even permanently, if you aren't careful.
Handling is nice, colour rendition is beautiful and so is bokeh given you master the DC settings. Sharpness is very good to excellent, but the lens needs to be stopped down a little lest residual aberrations should give a soft-looking overlay to a sharp core.
Thus, an uncommon and potentially difficult to use lens that can be very rewarding used for its intended purpose, viz. portraits or details.
Ensure the copy works well and the aperture isn't sticky. Manual focusing should be smooth with a little but evenly distributed drag to it. Look out for evident cracks around the screw(s) of the A/M collar.
A reasonable price for a clean sample would be 2-3(4) times that of the 105/2.5 and 1.5-2 times that of the 105/1.8 Nikkors.
Grahame Hamblin
« Reply #2 on: August 18, 2015, 21:33:29 »
Thank you that was very helpful
Grahame
« Reply #3 on: August 18, 2015, 21:46:42 »
Thanks. Please keep us updated whether you buy it and if so, what results you get from it.
Grahame Hamblin
« Reply #4 on: August 19, 2015, 21:08:59 »
Hi Bjorn the lens seems in good condition the price about $700 American dollars equivalent is that a fair price
Grahame.
« Reply #5 on: August 19, 2015, 21:14:39 »
Fair enough I'd say. A clean 105/2.5 of the later versions easily runs around $200- 250. So the asking price is just inside the bracketed range I suggested earlier.
