Author Topic: Nikon O 35 2,0  (Read 2453 times)
Lumens Pixel
  • You ARE NikonGear'23
Nikon O 35 2,0
« on: February 26, 2026, 22:36:20 »
I wish to share my views about the Nikon O 35 2,0 that infuriates me but that I keep using on a Sony A7II with a dumb adapter.
First thing I do when buying a lens:  a test shot at infinity at various f stops. Quite disappointing. A part from a center zone, nothing sharp before f4,0. Acceptable sharpness at f5,6 with some midzone dips and good quality starting from f6,7.
So why use a heavy fixed focal lens when a plastic zoom would deliver sharp results already by f4,5 (Nikon 28-80 3,3/5,6 amongst others)?
The lens went back to storage for a while. I did test a Nikon AI 35 2,8 (6 elements) that provided greater homogeneity starting from f5,6 but was quite bad at wider apertures.
Out of curiosity I used it at home for a portrait, wide open at f2,0 and the result was stunning. Perfectly sharp and very nice bokeh. I was clueless and tested it more. I understood that in the central area the lens was perfectly sharp and that sharpness extended while closing the diaphragm.
I was not accustomed to this behaviour. The other 35mm I was using were the Canon nFD 35 2,8 and the Minolta MDIII 35 2,8 that are more modern designs, already sharp wide open on a large part of the frame and closing the diaphragm only increases global micro contrast and extends sharpness to the extreme corners. But none of these lenses could be tack sharp in the center at f2,0 and the bokeh was less interesting.
With some additional testing I realised the lens is affected by a "wavy" field curvature and that very good sharpness could be reached starting from f4,5 on various part of the frame provided focusing was adjusted on such part of the frame. I do not know if Sony sensor stack has an impact here. Any test on a Kolari modded camera or, to a lesser extent, on a Nikon Z could provide interesting information.
So this was not (at least my copy) a good landscape lens under f6,7 but it could deliver very pleasing results from wide open if you care for framing and focus adequately on "3D" subjects.
Upon reflection that is a sensible use case for most of my practice and I do enjoy the rendering of this lens.
I still do not know, after reading some opinions on the web, if the computation was changed in late production. If that is the case I might buy someday an AI or AIS copy. I would like to read the advice of someone who had the opportunity to compare the early and late versions.
Some pics :
Forêt de Fausses Reposes by lumens pixel, sur Flickr
Lavande by lumens pixel, sur Flickr
Début d'automne by lumens pixel, sur Flickr
Spider jewellery | Versailles by lumens pixel, sur Flickr
Métro Grands Boulevards by lumens pixel, sur Flickr
DSC01867ra by lumens pixel, sur Flickr
DSC01871ra by lumens pixel, sur Flickr
Re: Nikon O 35 2,0
« Reply #1 on: February 27, 2026, 04:41:08 »
It appears that your long learning process with this lens is paying off with nice results. I owned one in the film days, so have no insight about how it works on any digital.  Your observations on this lens roughly comport with my experience using it on film.  I usually shot at f/8 or f/11 in bright light because of odd lack-of-sharpness effects I got when using it wide open or at f/4.  I often wonder how the present day digital performance of these classic Nikkor wide angle lenses is affected by the sensor filter stack, an optical element that wasn't present on film cameras.
Re: Nikon O 35 2,0
« Reply #2 on: February 28, 2026, 23:00:57 »
I like several of the results you've shown us here Michel
Re: Nikon O 35 2,0
« Reply #3 on: March 01, 2026, 05:36:17 »
This article is well worth reading: https://imaging.nikon.com/imaging/information/story/0084/
This article says that the optical design of the original Nikkor-O 35/2 was never changed and continued through the AI and AI-S versions. It also has discusses lens performance compared to the Nikkor 35/1.4.
Lumens Pixel
Re: Nikon O 35 2,0
« Reply #4 on: March 01, 2026, 10:16:57 »
Colin and Keith, thank you for the nice words.
Roland, this is a very interesting read. I take the opportunity to thank you for the wealth of information you diffuse about Nikon lenses that helped me a lot with my purchases.
Gerhard2006
Re: Nikon O 35 2,0
« Reply #5 on: March 04, 2026, 18:41:06 »
I bought this lens in the film era as well and after I compared it to my 36-72 series E zoom, I sold the zoom. It was so sharp I just loved that lens until I found a mint Ais version. It had better resistance to flair compared to the old lens. However I took a shot of a friend who had just bought a Rollieflex 2.8F and even though it was close to the edge of my the frame I could still read the name Zeiss on the lens very clearly. It was a PJ lens and is very good from close up to 3 meters. I shot many of weddings with that lens as it was my main lens for years until I found a 35 1.4 Ais lens and so I gave it to my son who immediately fell in love with it. It is also an excellent macro lens when reversed, yielding 1.5 lifesize. I guess that’s why they never changed the design like Roland mentioned. So hold onto it, it’s a great lens although the 1.4 version is a little sharper and has better flare  control although on video flare can be a useful tool. Regards Gerry
Lumens Pixel
Re: Nikon O 35 2,0
« Reply #6 on: March 04, 2026, 18:44:27 »
I bought this lens in the film era as well and after I compared it to my 36-72 series E zoom, I sold the zoom. It was so sharp I just loved that lens until I found a mint Ais version. It had better resistance to flair compared to the old lens. However I took a shot of a friend who had just bought a Rollieflex 2.8F and even though it was close to the edge of my the frame I could still read the name Zeiss on the lens very clearly. It was a PJ lens and is very from close up to 3 meters. I shot many of weddings with that lens as it was my main lens for years until I found a 35 1.4 Ais lens and so I gave it to my son who immediately fell in love with it. It is also an excellent macro lens when reversed, yielding 1.5 lifesize. I guess that’s why they never changed the design like Roland mentioned. So hold onto it, it’s a great lens although the 1.4 version is a little sharper and has better flare  control although on video flare can be a useful tool. Regards Gerry
Thank you Gerry for your comments. I agree the lens shines at mid distances which is perfect for photo journalism.
Re: Nikon O 35 2,0
« Reply #7 on: March 04, 2026, 20:55:38 »
I own one or maybe two 35/2.0 AIS Nikkors. I consider it a very good lens for the era. I printed for a PR photographer that use this lens almost exclusively. Always excellent focus. Always at f/5.6 with a Vivitar 283 at 60* bounce. I showed him a photo of Jimmy Carter's official photographer using a Vivitar 283 or 285 at 90* and a 3x5" index card for fill. He never used a fill card. Now they are built in many Nikon speedlights. In doors the light from the 283 spilled onto the wall near the ceiling and I cropped it off.
I probably owned the early single coated 35/2.0 but don't remember. I sold completely out of Nikon when Pentax announced multi-coating and bought back into Nikon when they released the F2As and AI Nikkors. I recommend the AIS version. I always wanted to add a 35/1.4 AIS but never did.
Re: Nikon O 35 2,0
« Reply #8 on: March 06, 2026, 15:28:52 »
As you mention yourself, the sensor filter pack is not helping, many tests have shown that 'old' lens designs often have difficulties on these cameras. Including Nikkor and Leica lenses
Lumens Pixel
Re: Nikon O 35 2,0
« Reply #9 on: March 06, 2026, 19:10:08 »
I am certainly not going to invest money in the last Leica camera to benefit from a thin sensor stack. Sure a Kolari mod is more affordable but the very thin filter results in colorimetry changes that might lead to uncomfortable results.
If anyone equipped with these old lenses would be kind enough to comment on filter differences it would be immensely helpful. There has been a very good article published on Philip Reeve's website one could read here: https://phillipreeve.net/blog/review-kolari-ultra-thin-sensor-stack-modification/
The article is quite dismissive about the impact of the sensor on SLR lenses, the author focusing on rangefinder lenses. But I am interested in other opinions.
