Author Topic: Guidance: Specific driver size for pre-AI slot rear mount screws  (Read 1292 times)
whatdoido
  • You ARE NikonGear'23
Are there specific sizes of drivers for rear mount pre-AI slot screws?  Richard's site suggests that the screws are not always a uniform/consistent size.
I'm trying to remove the mount of a 55mm Micro P
Re: Guidance: Specific driver size for pre-AI slot rear mount screws
« Reply #1 on: December 15, 2025, 05:53:39 »
I also would like to know if there are specs for the slot screws that Nikon used in that era.  One solution that always works IF you have the patience and can sacrifice an otherwise good screwdriver: Pick a slot driver that is slightly too big, and file it down so it fits.
« Reply #2 on: December 15, 2025, 09:27:36 »
I can recommend a set of Wera screwdrivers, get a set of all of the small ones, there are many more as soon as you get the mount of  ;D
whatdoido
« Reply #3 on: December 20, 2025, 17:59:08 »
Eric isnt wrong here - the joys after I took a late MIcro Nikkor-P Auto 55m apart - interestingly, internally it looks like the PC Auto that Richard covers (3x on the helicoid key)
  • front retaining ring grub screw - 1.2mm
  • 5x Rear slotted screws on a factory AI conversion - 3mm??
  • 3x helicoid key screws GLUED - 3mm??
  • 3x chrome grab-distance sleave screws - 1.8mm??
  • 3x focus ring screws covered by GLUED - 1.8mm???
