Author Topic: Database error  (Read 7416 times)
Database error
« on: October 09, 2025, 12:30:44 »
I've been getting this error whilst trying to post.
Consistently for half an hour or so
Re: Database error
« Reply #1 on: October 09, 2025, 16:17:18 »
Clear your browser cache and try again.
I'll do a maintenance run on the db. There was a short series of db issues pertaining to a couple of other members as well.
Re: Database error
« Reply #2 on: October 09, 2025, 16:39:08 »
You didn't use some special characters, like an Emoij?
The error log message complains about a character not in the multi-lingual base set.
Re: Database error
« Reply #3 on: October 09, 2025, 19:19:59 »
No special characters.
Though it did let me post the words "test message",  it wouldn't let me post what I wanted to write...
Re: Database error
« Reply #4 on: October 09, 2025, 20:48:09 »
Strange bug that hit you and another member this afternoon?? Everything else went smoothly, or at least, the logs don't show error messages other than the two concerning you and another member.
Technically, the error is trigged when a 4-byte string is sent into the db, which only handles 2 or 3 byte entries.
Ann
Re: Database error
« Reply #5 on: December 21, 2025, 00:02:49 »
I am curious about why this happened: I couldn't get NikonGear to open today at all.
Then I added the ".php" suffix and the site opened immediately
Now I can get in with just my regular sign-in without the need for the .php suffix.
I use the Safari browser and this has happened since the last Update of  Mac OS 15.7.3.
Is this just an anomaly or should I add the suffix in the future?
Re: Database error
« Reply #6 on: December 21, 2025, 08:26:42 »
The .php is default, so the issue this time can be laid at the browser's door. Adding the suffix shouldn't be required. In fact, you should be fine by dropping /index.php all together.
We have the occasional data base errors, but I run a maintenance app when this happens and I get the admin error message.
Ann
Re: Database error
« Reply #7 on: December 21, 2025, 21:29:06 »
I guess it was just a "fault in the Matrix" then because today I can get in without adding any suffix at all — as I normally do!
Or perhaps Apple fixed something?
Re: Database error
« Reply #8 on: December 21, 2025, 23:13:44 »
I haven't used Apple products for ages, but still get weirdness on NG using Windiws & Android from time to time. Rarely enough to not be concerned about it :)
