Author Topic: Adapting Zeiss 180/2.8 for Nikon  (Read 1659 times)
Matthew Currie
« on: October 07, 2025, 02:30:24 »
My local shop had a somewhat stiff but decent looking Zeiss Jena 180/2.8 in Exakta mount (serial number suggests about 1947) and after it sat around for some months, I found myself unable to let it languish, so lighter by ten bucks, I figured I ought to be able to do something with it, at worst fire up my old East German Exakta and expose some film.  But when I got it home, I realized that the adapter is wonderfully simple in design.  Photo should show this.  It's a piece that's just spigoted into the body of the lens, and held on by a threaded collar, so the adapter itself needs no threads.  So I rummaged in my scrap pile and came up with an aluminum piece - I think it was originally a hub from some long ago film processing equipment - that I was able to machine down to make a Nikon mount, with the bayonet from some now forgotten broken lens. Given that the register distance of the Nikon is only about 1.8 mm. different from the Exakta, there's plenty of room.
It's not killer-diller sharp, but not bad, though pretty hard to hold given how big and heavy it is.  But anyway, I was able with a little fiddling to get it to focus to infinity, and got the focus and aperture limbered up enough to work, though still tight.  I shot down toward the backyard pond, handheld, and at least came up with an image.  More experimenting in daylight conditions is called for, and maybe some focus fine tuning, but it seems promising, despite being a little long for use on DX.  It is, if nothing else, a very impressive hunk of glass!
Re: Adapting Zeiss 180/2.8 for Nikon
« Reply #1 on: October 07, 2025, 08:28:01 »
Oh, the famous Olympia Sonnar ... Erik converted one of those for me, and added  a CPU as well. By modern standards it's not the sharpest lens in the cupboard, but not that bad either. CA is mitigated to a large extent if you shoot b/w.
You reminded me I ought to pull out the lens and investigate it for IR.
Thomas Stellwag
« Reply #2 on: October 07, 2025, 12:08:01 »
mine looks like that
Thomas Stellwag
« Reply #3 on: October 08, 2025, 11:24:39 »
Just tried the Zeiss 180mm f/2.8 for IR on my modied Nikon Z5 with Kolari 720nm clip-in filter. At f/2.8, sharpness is so-so and there is a lot of spherical aberration, which actually gives a pleasing 'roundness' to the image. At f/5.6 the image sharpens up and the fuzziness is largely gone. Image contrast is still on the medium-low side, though. No IR hot spots were detected. The Zeiss may see future use for special IR images for which the IR "glow" is important.
I ran direct comparison in IR against the Nikor 180mm f/2.8ED AiS and the Leitz APO-Telyt-R. Both lenses are very clearly superior to the old Zeiss behemoth as far as image sharpness is concerned. Apparently they both are devoid of the dreaded IR hot spots as well. Image sharpness at f/5.6 was a tie, perhaps with the Leitz an ever so slightly bit ahead, but that differenece might well be imaginary or scene dependent. They are excellent lenses for IR and of course the Nikkor 180 is way better interfacing with native F/Z cameras since all lens features work perfectly. The Leitz is more awkward to use on any non-native camera since aperture is not automatic, but the half-stop slower "speed" makes it narrower and lighter than the bulky Nikkor.
