Author Topic: Nikon F 35mm f2.8s  (Read 1962 times)
Robert Camfield
  • Hello from MadTown
Nikon F 35mm f2.8s
« on: September 06, 2025, 18:33:01 »
In comments from a few years back—2019 or so—Roland opined that the 6 element/6 group variant of Nikon’s 35mm f2.8s for the F was likely the best, optically. I have an unorganized collection of the more common pre-auto focus F lens, and exploring this claim has been on the agenda for some time. I got to it last week...the usual ad hock test including tripod and common subject (a street sign), distance, and lighting. So, yes, the 6-element version of the 35 2.8s (i.e., the early AI variant, which also sold as a K lens) appears to be the best, notably in the corners at all apertures. Interesting to me is the successor 5 element lens (late-AI and AIS): it’s pretty good, despite the simple optimal performance. I should mention also that, for resolution, the original 35mm f1.4s—in this case, an early production sample (#351676)—seem to be at least as good as the 2.8s, for apertures f2.8 – 8.0.
Re: Nikon F 35mm f2.8s
« Reply #1 on: September 07, 2025, 08:56:53 »
This comports with my observations: The 35/1.4, once stopped down to f/2.8, is the best of all.  My old several-times-disassembled copies of the 35/2.8 K/Ai 'New Nikkor' have much field curvature at infinity, but seem to be optimised at a mid-distance, like maybe 2-3 meters. Pre CRC, Nikon seemed to often pick a medium distance to optimise the rendering for, instead of infinity.  Pre-CRC, this was probably a good idea for their reputation with pros and photojournalists who mostly shoot people doing things at intermediate distance.
Robert Camfield
« Reply #2 on: September 07, 2025, 19:40:00 »
Thanks for your comments. To clarify, the distance for these comparisons was about 30 meters...Nikon may well have optimized performance shorter distances for these early 35s, as you suggest. Generally speaking, ad hoc comparisons such as these tend to confirm the consensus view. Accordingly, the 24mm f2.8 AI/AIS appears to have noticeably higher resolution than the 24mm f2.0 for apertures 2.8-5.6, with performance of the f2.0 (in my case, an AI variant) approximating that of the 24 f2.8 by f8/f11.
« Reply #3 on: September 08, 2025, 05:53:23 »
Birna discovered, a few years ago, that the Ai-era 24/2.0 is very sensitive to the internal CRC mechanism being knocked out of proper alignment.  This physical vulnerability has led, over the decades, to reports and observations of some copies of the lens being very good and others being noticeably not as good. I think that the famous 28/2.8 AiS has this same vulnerability.
Robert Camfield
« Reply #4 on: September 09, 2025, 00:44:27 »
Yes, it seems that I recall Birna mentioning the issue...also, Richard Haw indicated, in a response to an earlier post, that the CRC mechanism of the 28 f2.8 AIS could be calibrated, suggesting variation across samples. My 24 f2.0 AI disappoints, while the 28 f2.8 AIS proves to be superb.
« Reply #5 on: September 14, 2025, 03:03:28 »
That is interesting. The Nikon article on the AI 35/2 suggests it is sharper than the 35/1.4 in some parts of the image (at far distance at least)
https://imaging.nikon.com/imaging/information/story/0084/
I once did a brief test to compare my K 35/2.6 (6/6 elements) with my AIS 35/2.8 (5/5 elements). They were pretty evenly matched. Both have low barrel distortion and sharpness was pretty good on both lenses - centre and corners. The AIS version has a reputation of not being as good due to the simpler optical design, but it looks like the Nikon engineers managed to maintain optical performance using a newer but simpler arrangement. The series-E 35/2.5 has a very similar 5/5 element design, sometimes confused with the AIS version, but I think it was stretched to be 1/3 stop faster and more compact, at the expense of optical performance.
« Reply #6 on: September 14, 2025, 07:13:43 »
My recollection is that the 35/2 K/Ai/AiS was perfectly sharp in the central area, but showed more blur towards the side of the frame, while the 35/1.4 K/Ai/AiS, once stopped down to f/2.8, gave a better impression of the central sharpness extending all the way out to near the edges.  However, I never owned both at the same time and memory is a tricky thing.
Robert Camfield
« Reply #7 on: September 15, 2025, 20:22:15 »
I don't take issue with Roland's comments, above. Specifically, while it seemed to me that the F2.8 6/6 is better in the corners than the 5/5, the differences are not starkly obvious...in my case, a back-and-forth comparison at 200%, and was carried out only one distance. As Roland mentions, the 5/5 holds up well, and noticeably improves on my pre-K variant, an AI'd 7/6. I have no experience with the 35mm F2.0.
Robert Camfield
« Reply #8 on: September 16, 2025, 03:52:02 »
Adding further to the dialogue...it would not surprise me if the 35 F2.0 provides improved performance over the F1.4 in the presence of bright lights, where coma can be pronounced at the wider apertures of the 1.4...as shown in Nikon Tale #84 (referenced by Roland). To this point, I've noticed that image degradation due to coma is occasionally mentioned in many reviews of the F1.4.
« Reply #9 on: September 16, 2025, 07:12:14 »
Yes, the 35/1.4 is famous as a "dual look" lens.  Wide open, it has the ethereal haze laid over a sharp image underneath.  By f/2.8, it's contrasty and "normal".  The 50/1.2 Ais has a similar 'haze wide open, sharp after f/2.8' effect.
