Author Topic: September 2025  (Read 42617 times)
Re: September 2025
« Reply #60 on: September 06, 2025, 08:36:15 »
I "reconfigured" my Z30 for use as a quasi-rangefinder camera working with the old Voigtländer 15mm f/4.5 SL lens. This comprised putting the rear display to the 'protected' setting with the monitor on the inside and metal outwards, semi-permanently adding an optical peep-through framefinder, and adjusting the focus on the 15mm with a dedicated F-Z 'dumb' adapter so I could rely on the engraved focus scale on the lens. It even has click-stopped settings at 0.5 and 1m, and a hard stop at the ends at infinity and 0.3m, and in combination with the built-in focusing lever setting the lens to an approximate given distance without looking is quite easy, even more so after some practice runs. Following the ancient adage of 'f/8 and be there', and the modern invention of auto ISO sensitivity, allows for relaxed shooting. Eye-balling the frame coverage becomes second nature after a while.
The final touch is adding GPS recording. The usual approach, a Foolography device, won't work as that company now has gone down the drain with a junk product these days. Their '22 Unleashed' units are to be shunned at all costs. Using the Snapbridge app gives GPS input although co-ordinates aren't very accurate since they originate from the mobile phone. Best solution is putting a standard, small GPS logger in your pocket and use the potential of ExifTool to plow back GPS data into the NEF/jpg files. I wote a simple script to achieve this and provided the camera time is set correctly, this procedure works perfectly.
From a recent trip to Oslo to visit my dentist :)
City Greens
ARTUROARTISTA
  • I don't like ladybugs.
    • APM Pintor
Re: September 2025
« Reply #61 on: September 06, 2025, 10:17:27 »
  Beautiful graphic design Arturo
Thanks Paco, it's Cogulla Snake (Macroprotodon brevis), the photo is from a terrace of my house, they live around here, although it's difficult to see them.
un saludo
Re: September 2025
« Reply #62 on: September 06, 2025, 17:42:19 »
Yello...
Z9  AF-S  28-300
Re: September 2025
« Reply #63 on: September 06, 2025, 21:09:35 »
Monochrome structure
  z50II, 16-50mm 3.5-6.3 dx
Re: September 2025
« Reply #64 on: September 07, 2025, 06:42:11 »
Great job convincing the seagull to enter the frame in the *correct* position, Paco :)
Re: September 2025
« Reply #65 on: September 07, 2025, 06:43:48 »
Those were the days
aerobat
Re: September 2025
« Reply #66 on: September 07, 2025, 08:33:07 »
Cutie - Z30 & AF-S 300mm PF
Daniel Diggelmann
Re: September 2025
« Reply #67 on: September 07, 2025, 09:19:04 »
do not look through the view finder if you want a nice selfie!
Re: September 2025
« Reply #68 on: September 07, 2025, 09:46:45 »
Nice tatoo!   :D
Re: September 2025
« Reply #69 on: September 07, 2025, 10:56:56 »
An on/off capable tattoo :)
ARTUROARTISTA
    • APM Pintor
Re: September 2025
« Reply #70 on: September 07, 2025, 14:23:15 »
another tattoo
Re: September 2025
« Reply #71 on: September 07, 2025, 14:47:27 »
That marking really screams 'DON'T EAT ME!! I TASTE BAD!!'
ARTUROARTISTA
    • APM Pintor
Re: September 2025
« Reply #72 on: September 07, 2025, 19:23:14 »
Bed bugs are very smelly, it's better not to touch them,
aerobat
Re: September 2025
« Reply #73 on: September 08, 2025, 05:40:22 »
Vanessa Atalanta - Z30 & AF-S 300mm PF
Daniel Diggelmann
Re: September 2025
« Reply #74 on: September 08, 2025, 07:25:10 »
You keep doing well aiming the 300PF without a viewfinder.
Someone preparing for the winter (14-30mm @  f/7.1 on  Z5II) :
