Author Topic: Lens from a 19th-century magic lantern.  (Read 316 times)
ARTUROARTISTA
  • I don't like ladybugs.
    • APM Pintor
« on: August 27, 2025, 11:54:14 »
Can it be adapted to a modern camera?
Re: Lens from a 19th-century magic lantern.
« Reply #1 on: August 27, 2025, 14:31:43 »
Probably. Whether it is going to be useful or practical, depends among other considerations on what focal length it has. If long, the likely alternative, you might need added extension to make the lens focus to anything closer than infinity.
You don't need to know the exact focal length, merely what the distance will be from the rear end of the lens to the sensor/film plane. Easily observed by projecting an image of the sun or other bright objects onto a sheet of paper and moving the lens back and forth to focus the test target seen on the paper sheet. Be aware that the sun might set fire to the paper when you nail the infinity focus :)
ARTUROARTISTA
    • APM Pintor
« Reply #2 on: August 27, 2025, 22:03:10 »
Thanks, Birna. I see what I can do with your instructions. I think that's a huge distance, 17 cm.
« Reply #3 on: August 27, 2025, 22:45:20 »
Hmm. Makes using it for ordinary photography a bit complicated, unless you have a long bellows device :)
ARTUROARTISTA
    • APM Pintor
« Reply #4 on: August 27, 2025, 23:01:55 »
I've reached 14 cm. I think I'll have to buy a bellows like you say Birna.
« Reply #5 on: August 28, 2025, 15:02:17 »
Maybe a length of blackened plastic water pipe of a suitable length and diameter - certainly inexpensive for proof of concept purposes.
ARTUROARTISTA
    • APM Pintor
« Reply #6 on: August 28, 2025, 17:04:35 »
That's a good idea. Thanks, Hugh.
