Author Topic: TelyT-R Adapter.  (Read 2202 times)
Leophallak
TelyT-R Adapter.
« on: August 11, 2025, 21:12:42 »
What is the recommended adapter for Leica R to Z? Picked up a mind Telyt-R 350mm at a estate sale.
Thank you,
Leo
Re: TelyT-R Adapter.
« Reply #1 on: August 11, 2025, 22:47:00 »
Rayqual tends to make good adapters.
https://www.ebay.co.uk/itm/388821832433
« Reply #3 on: August 12, 2025, 02:39:34 »
I've been using Rayqual adapters for m4/3, Fuji, Leica-L and Sony FE mounts and never been disappointed.
I can also recommend Novoflex adapters without reserve.
« Reply #4 on: August 12, 2025, 08:06:32 »
I have a few Novoflex adapters, they're pretty nice.
Jürgen Pfeiffer
  • You ARE NikonGear'23
« Reply #5 on: August 12, 2025, 09:27:13 »
Another possibility would be to connect the Telyt equipped with a Leica R to Sony E adapter to a Sony E to Nikon Z adapter (e.g. Funmount ETZ Pro). This gives the Telyt focus confirmation and the focal length and speed are automatically transferred to the camera. With a 350mm lens, focus confirmation is a great thing.
Jürgen Pfeiffer
« Reply #6 on: August 12, 2025, 11:34:47 »
Stacking adapters *might* lead to instability or wobbling of the lens attachment. Plus, since most third-party adapters tend to be a smidgen on the short side, you can end up losing a lot of the near focus range, in order to still reach infinity focus. The latter is  a real issue with shorter focal lengths.
Jürgen Pfeiffer
« Reply #7 on: August 12, 2025, 15:05:51 »
Hello Birna, as you said: “might”, but doesn't have to. I have several cheap Nikon F to NEX adapters from China and each one has the correct infinity setting when combined with a NEX to Z adapter (24mm to 500mm). I also have a few F to Z adapters that are too short, but nothing that can't be solved with a screwdriver and some thin metal foil...
For me, the ability to use manual non-CPU lenses with working focus confirmation is a big advantage, especially the longer focal lengths from 135mm.
Jürgen Pfeiffer
« Reply #8 on: August 12, 2025, 17:54:42 »
Impressive cat shot whith a storm of amber tones!!!
Jürgen Pfeiffer
« Reply #9 on: August 12, 2025, 18:03:45 »
…whith a storm of amber tones!!!
if you could see the underbelly… :) :)
Jürgen Pfeiffer
Leophallak
« Reply #10 on: August 12, 2025, 18:40:10 »
Thanks, everyone, for the advice.
Leo
