Author Topic: August 2025  (Read 36759 times)
Re: August 2025
« Reply #30 on: August 03, 2025, 23:58:34 »
Fresh from the starship.
  D5300 ir; 35mm f2 ais
Adli Wahid
Re: August 2025
« Reply #31 on: August 04, 2025, 10:32:15 »
My purple pea bush (Hovea acutifolia) in the yard.
D7200 + AF-S Nikkor 70-300mm
Re: August 2025
« Reply #32 on: August 04, 2025, 16:37:09 »
I felt i had to look this one up, thanks for showing!
https://backyardbuddies.org.au/backyard-buddies/purple-pea-bush
Re: August 2025
« Reply #33 on: August 04, 2025, 16:38:13 »
August 3
berries
d850  -  afs 24-70mm f/2.8
Ian Watson
Re: August 2025
« Reply #34 on: August 04, 2025, 17:44:43 »
Thank you, Akira and Thomas.
Akira, you mentioned the composition. It was surprising how important the drain and seam in the floor were. The photograph would be unbalanced without them.
Ian Watson
Re: August 2025
« Reply #35 on: August 04, 2025, 17:46:01 »
On the subject of composition, having taken a more typical photograph of the bartender, I tried something a little different. She is smirking at my antics  :)
Nikon Zf, 35mm f/1.8S
Chip Chipowski
Re: August 2025
« Reply #36 on: August 05, 2025, 05:52:12 »
D810 w 70-200 + TC1.7
Re: August 2025
« Reply #37 on: August 05, 2025, 06:21:42 »
let us share that 60:60
Norwegian landscape 2025
ARTUROARTISTA
  • I don't like ladybugs.
    • APM Pintor
Re: August 2025
« Reply #38 on: August 05, 2025, 09:52:20 »
blanco y negro con una D200
Re: August 2025
« Reply #39 on: August 05, 2025, 11:49:54 »
Roses, Rosa x "Aloha"
Nikon Z7_2,  Voigtländer 65mm f/2
Rosa ‘Aloha’ is a climbing rose that was bred by Gene Boerner.  ‘Aloha’ was first introduced in 1949.
ARTUROARTISTA
    • APM Pintor
Re: August 2025
« Reply #40 on: August 05, 2025, 15:13:51 »
reunión de amigos
Re: August 2025
« Reply #41 on: August 05, 2025, 15:20:38 »
Re: August 2025
« Reply #42 on: August 05, 2025, 17:24:48 »
car meets car in IR
Re: August 2025
« Reply #43 on: August 05, 2025, 19:42:11 »
On stage. Low light with limited color palette put the Z9 to the test with the 70-200 2.8 fl at iso 3200. The files are surprisingly flexible -not Z6 flexible but closer than i thought-.
  Meet N.T. She is a very talented dancer
ARTUROARTISTA
    • APM Pintor
Re: August 2025
« Reply #44 on: August 05, 2025, 21:00:26 »
gran angular macro
