Author Topic: Cannot modify my posts  (Read 8189 times)
Lars Hansen
  • Zealand, Denmark
« on: July 12, 2025, 13:12:43 »
Since yesterday, I'm no longer able to modify my posts.
Yesterday, I created a post and modified it - removed an image and added another version and I got an error about "maximum images...". After that I cannot modify any of my posts - the "modify" option is missing.
/Lars
Re: Cannot modify my posts
« Reply #1 on: July 12, 2025, 14:16:31 »
There is a time window for modifications.
We had to implement that some time ago as some members thrashed threads when discussion temperaments flared.
I'll look into the window setting.
« Reply #2 on: July 12, 2025, 14:33:00 »
OK Lars, try again. Do note the number of attached images per post has been lowered rcently, from 10 before to 4 now. Just keep that limit in mind.
You might log out, then in again, before attempting to change anything.
Lars Hansen
  • Zealand, Denmark
« Reply #3 on: July 12, 2025, 15:02:20 »
Many thanks, Birna - I just logged in again and it seems to work now on both recent and older posts. The modify option was missing on both older and recent posts - also after logging off and on again.
Could you elaborate a bit on the time window for modifications - as said above, the error was also present for all older posts I looked at. It seems the time window is related to ones account and not a specific topic?
The error I received was probably due to the 4 images limit - I was uploading some new versions and might have forgotten to remove the existing ones.
« Reply #4 on: July 12, 2025, 15:11:57 »
The time window for editing is indeed linked to your membership class and thus affects all posts. I have disabled the time limit for now. Let's keep an eye on the possible side effects (people thrashing threads by removing content and thereby removing coherency of a discussion).
Only admins can delete posts, thus the thrashers will leave a trail of "bread crumbs". However once content is gone, we cannot restore it unless the entire site is rolled back to the latest backup. Mainly meaning the state of yesterday.
A hint for editing attachments: clear the check box for the attachment(s) you wish to change first, then add a new version.
