Author Topic: Spring Green Frog with the Hasselblad XCD 135mm_1.7 Tele  (Read 3516 times)
Hasselblad X2D
Green Frogs to the vernal ponds.
KarlMera
Re: Spring Green Frog with the Hasselblad XCD 135mm_1.7 Tele
« Reply #1 on: May 05, 2025, 14:24:51 »
Hasselblad X2D
The price-performance relationship is not good enough for this picture, only my opinion.
« Reply #2 on: May 05, 2025, 15:17:29 »
Hasselblad X2D
Ay, Michael!
Can you describe the special quality you see here compared to a Nikon / Sony / iPhone 16?
Please share for us to understand
Thank you!
« Reply #3 on: May 05, 2025, 22:04:53 »
Ay, Michael!
Thank you!
Nothing to understand. I don't think of it that way. I could shoot this with any of the above, other than the iPhone 16 Pro Max, which I have.
I just happened to have the Hasselblad XCD lens and there was this frog. I'm not justifying my use of the Hasselblad. I just happen to have it at the time. It's a larger image than Nikon or Sony could provide me other than some pixel doubling or something.
« Reply #4 on: May 05, 2025, 23:36:19 »
The best camera *always* is what you have at hand. Use it within or outside its expected operational range.
« Reply #5 on: May 06, 2025, 15:39:22 »
Nothing to understand. I don't think of it that way. I could shoot this with any of the above, other than the iPhone 16 Pro Max, which I have. I just happened to have the Hasselblad XCD lens and there was this frog. I'm not justifying my use of the Hasselblad. I just happen to have it at the time. It's a larger image than Nikon or Sony could provide me other than some pixel doubling or something.
Thank you for your thoughts.
My feel is that I try to utilize the cameras I have by using equipment that is best for the purpose and trying to use the full potential of the equipment as often as possible.
If I know in advance what I am going to shoot I do think very thoroughly about my equipment choice.
If I do not know what to expect I take a kit to be more versatile. E. g. I was sooo happy to have taken my D500 to Spain because I had a lot of tele work in the end and would have to cut our a lot more of the frames if had taken the D850.
Is there a H2D-Kit you take with you if you do not know wht to expect?
Love
Frank
« Reply #6 on: May 09, 2025, 20:34:41 »
If I just go out hiking, I either take the XD HB 28mm lens because it is so lightweight AND quite sharp, if you are not worried about the edges, which with any non-landscape image I am not.
If I want to almost hike and carry a heavy-ish lens, it would be the new 20mm-35mm f/3.5-4.5 Zoom because it is THAT good, at least for the work I do.
If I don’t care about weight and want the best lens that the X2D camera can handle (again: for my work), that would be the XCD 80mm f/1.9. There is no better lens because I need a fast lens that is also sharp. There is no other.
If I want to travel somewhere (I won’t leave these in the car, ever), and don’t know what I might shoot, I would take these lenses:
XCD 20mm-35mm f/3.5-4.5 Zoom [very useful lens]
XCD 80mm f/1.9 [sharp and fast]
XCD 85mm f/2.8 [sharp and fast]
XCD 30mm f/3.5 [sharp]
XCD 120mm f/3/5 [for near macro]
XCD 28mm f/4 [walk around and more]
A short version of this would be:
XCD 20mm-35mm Zoom f/3.5-4.5
Just a single lens:
As I have been known to stack focus, I should mention that after I obtained the Hasselblad X2D, I am kind of cured of stacking focus.
The Hasselblad XCD lenses have such intense granularity that where I used to struggle to get things (like ‘everything’) in focus, thus focus stacking, I am no longer interested in that or if I do, I create what I call ‘Short Stacks’, meaning 2 or 3 images and stack those.
However, more and more I have shifted from worrying about sharp focus to composition. The Hasselblad X2D is to blame and I am very grateful to have this medium-format camera. I now shoot for ultimate composition rather than sharpness.
Where with my Nikon system, I endlessly tried to get the color right, with the X2D there is none of that. Sure, I can fiddle with the temperature or whatever, yet I don’t find myself doing that. As they say “Who woulda’ thunk it.”
Here is a rather dark photo, but I like dark because it was dark where I found it. Taken with the X2D and the XCD 28mm f/4 lens. You can see my shadow taking the photo.
 I feel I am finally free to just take photos.
If you are interested in what I am experimenting with, I could post it here, but it is several paragraphs.
« Reply #7 on: May 11, 2025, 09:02:43 »
Thank you, Michael!
