Author Topic: April 2025  (Read 30160 times)
christeo
    • CHrister Hoel Olsen foto
Re: April 2025
« Reply #420 on: April 26, 2025, 07:04:03 »
Twin peaks (Store Austanbotntind and Store Ringstind in western Jotunheimen). From a recent spring backcountry ski trip
  • Fairbanks, Alaska
Re: April 2025
« Reply #421 on: April 26, 2025, 07:56:54 »
Beautiful,  Hurrungane is a really nice (and dramatic) mountain area!
The 24-120mm S did it well.
christeo
Re: April 2025
« Reply #422 on: April 26, 2025, 10:11:12 »
Thanks Øivind. Yes, Hurrungane is beautiful, especially covered in snow.
The 24-120S is perfect for this kind of trips. In fact, it is very good for a very high percentage of my photography these days (almost boring, as my primes and teles are more seldom used).
KarlMera
Re: April 2025
« Reply #423 on: April 26, 2025, 10:50:13 »
Colored sculptures
Re: April 2025
« Reply #424 on: April 26, 2025, 11:41:35 »
Hot air balloon show at the town hall square.
Z8 z24-70 f4 @30mm 1/20 sec ISO 500
Copenhagen, whats the occassion Bent?
Re: April 2025
« Reply #425 on: April 26, 2025, 12:09:04 »
What an awesome view!
Re: April 2025
« Reply #426 on: April 26, 2025, 12:36:31 »
The mountain edge in the foreground is where we see those long rows of people trekking towards the summit?
Re: April 2025
« Reply #427 on: April 26, 2025, 12:42:11 »
More down-to-earth photography ... I've been shooting IR recently like I did so many many moons ago, with the first DSLRs. Meaning there is no live view, and due to the opaque IR long-pass filter over the lens, you couldn't see anything in the [tiny peephole of] finder. Thus shooting was blindfold. And in fact, quite a bit of fun, as one never knew what the outcome would be.
Nikon D5300 (IR-modified), Nikkor 28mm f/2.8 AiS. Although this camera does provide Live View, and even a viewfinder option as the IR filter sits inside the mirror box, I decided not to use the feature, which was refreshing. Too bad the D5300 lacks a silent shutter mode.
Lining up for the bus
Re: April 2025
« Reply #428 on: April 26, 2025, 13:30:46 »
And here it is. After using my little modified Gitzo 120 Reporter legs for 26 years as my only tripod, I thought I deserved this new one while everything on the site was on NAB sale. The solution I ended up with is about the same weight and folded length as the Gitzo with separately added leveling platform, but now I have a tripod that can almost reach eye level with its integrated leveling platform and is quite a bit sturdier, instead of always being down with pads on my knees - a completely different experience for me.
Congratulations with your new tripod.
I have one of Leofotos smaller models, and it work fantastic, sturdy and very lightweight.
Re: April 2025
« Reply #429 on: April 26, 2025, 13:35:43 »
I am not sure, but the company behind does this yearly, some sort of promotion. Light and music during the show.
Re: April 2025
« Reply #430 on: April 26, 2025, 13:37:41 »
  Ben, what really caught my eye is the quantity of  cell phones and how many people is living the event through the screen. Impressive shot either way
Well I had to do “ Hail Mary” shots to, so in some way I also say some of it through the camera.
Re: April 2025
« Reply #431 on: April 26, 2025, 17:11:17 »
  I have been eyeing one if those for some time now. isn't it the same6as the "innorel" as in same tripod with different brand. The one Iwas looking at claims 30kg+.also with leveling plate and 75mm ball for adapter for video heads.How do you like it in general ?
  • Fairbanks, Alaska
Re: April 2025
« Reply #432 on: April 26, 2025, 21:11:02 »
  I have been eyeing one if those for some time now. isn't it the same6as the "innorel" as in same tripod with different brand. The one I was looking at claims 30kg+.also with leveling plate and 75mm ball for adapter for video heads. How do you like it in general ?
Thanks for the comments Bent and Paco. I think I have seen mentioned before that the products of Leofoto and Innorel come from the same factories, but a quick check indicates that the products while pretty similar are not identical and I did not see a product like the Leofoto G4 Pro geared head (that I previously got) among the Innorel products.
The presence of a leveling platform was one of my initial criteria's as it greatly simplifies setup with a tracker. I was initially set on one of the systematic tripods with option for a 75mm video bowl. However the weight increase was considerable when the video bowl was added, bringing weight up to about 2.4 kg. Also the wide size of the spider would makes it less transportable. That is when I discovered that the Ranger series came in a version with 32mm upper leg segments, so I settled on the LS-324CEX Leveling Ranger Tripod legs with integrated leveling platform that seems like a good compromise. Nominal weight is only 1.61 kg, and packs very tight due to the narrow spider. The nominal carrying capacity at 15kg is much less than the systematic version with 36mm upper legs (LM-364C X) at 30kg, but I think it will be more than adequate for most uses. I was also looking hard at the sealed Poseidon versions, but they lacked the leveling platform*, and the more exposed metal of the leg locks might be uncomfortable in the cold.
Getting a tripod that fits one's needs is really like looking for a good pair of good hiking boots, and one can get pretty bewildered by the wide range of selections that does not always have the desired combinations of features. Here is a link to an interesting video showing how the modularity of the Leofoto components allow assembly of custom tripods (but requires purchases of multiple tripods): https://www.youtube.com/watch?v=YLbvONDNFbY
*And here is what is apparently a South-African dealer assembling sealed legs with integrated leveling platform that are not available elsewhere (at a price...) : https://landscapegear.co.za/products/leofoto-agulhas-carbon-fiber-tripod-kit-lp-364cex-lh-47lr?srsltid=AfmBOoqEO9G--QOKOOpAhDozl2FkUuPgYVMerh6ccQZZTSlUVyuNhdmh
BTW I have for some time felt that my old Gitzo is on borrowed time. A while ago, most of the threads for one of the lower leg locks broke off due to rough treatment after the leg segment got bent and stuck. I initially thought that was it, and the Gitzo would become my cut down travel-only tripod legs.  But to my surprise the little that was left of the threads still worked. However that is when my tripod leg search became more serious, so it was an easy decision to go ahead now and beat the tariffs. Impressions so far are very positive. Added: Another event that made the final push was a hilarious lunar eclipse session with the Gitzo that do not have spikes and where leg locks are inactive by default (by my own chosen modification) on a slippy road. I purchased a set of sturdy claws for the Leofoto legs to supplement the included short spikes.
Re: April 2025
« Reply #433 on: April 26, 2025, 21:30:01 »
Who entered my showroom?
D5  28-300
Re: April 2025
« Reply #434 on: April 26, 2025, 21:32:14 »
