Author Topic: Nikon 12-24mm DX NIKKOR AF-S for astrophotography  (Read 2805 times)
oldfauser
  • From SE Wisconsin
« on: March 12, 2025, 22:58:34 »
I'm looking at a APS-C sensor based dedicated Asto Camera.  Ran across this lens,  the Nikon 12-24mm DX NIKKOR AF-S with ED glass and was wonder how good it is wide open @ f/4 at 12mm (18mm field of view)?  I will have to shoot it wide open as the camera adaptors cannot operate the lens aperture lever! Coma in the corners?
The price seems very reasonable for this focal length.
Thoughts?
Art
Re: Nikon 12-24mm DX NIKKOR AF-S for astrophotography
« Reply #1 on: March 12, 2025, 23:37:19 »
This extensive review would offer some food for thoughts:
https://www.lenstip.com/index.html?test=obiektywu&test_ob=292
I wonder if the lens is a bit too slow for the astrophotography unless you shoot start trails or track the camera?
MILLIREHM
  • Vienna, Austria
« Reply #2 on: March 13, 2025, 00:00:33 »
Make sure that it is possible to use it wide open with your adaptor. I might be wrong but IIRC the G type lenses are not set to wide open when not properly connected.
Wolfgang Rehm
oldfauser
  • From SE Wisconsin
« Reply #3 on: March 13, 2025, 00:34:35 »
I do have a star tracker, so f/4 is not too slow - and I was planning on adding a lever to the lens adaptor to hold the aperture lever in the open position.
i do have a 14-24 f/2.8 for a faster lens, but was thinking of something a little lighter!
Art
« Reply #4 on: March 13, 2025, 01:55:32 »
Here is a sample for you on the D500 at 13mm f/4.5 (open in new tab for larger version), which is what I typically used for optimal sharpness. I have not particularly been bothered by coma on this lens. (The 14-30mm S on a Z8 has even tighter stars, but very slightly elongated in the far corners.)  Over the years I used the 12-24 f/4 a lot for nighttime and aurora exposures, although usually not tracked. Generally distortions can be an issue when tracking very wide lenses. Of course tracking on stars vs blurring of the ground is another issue to keep in mind. The seldom occasions I have done the milky way on the DX sensors, I usually have used the 10.5mm fisheye. Are you planning to use it on a dedicated astro camera, and not a DSLR or mirrorless ?
For good performance of such a wide lens with adapters it will be important for register distance to be exactly the same as on the DSLR. The method I used with my ZWO ASI678MC and longer lenses was to first focus the lens on the DSLR body, tape focus ring so it is not moved, and then mount the astro camera, experimenting with different amount of shims on the adapter until I get good star focus. Once the right amount of shims is found, it can be used with different lenses.
oldfauser
  • From SE Wisconsin
« Reply #5 on: March 13, 2025, 02:10:30 »
I'm planning on using an ASI2600MC-PRO, or similar.  The tracker is to be able to take multiple 20 second shots of the Milky Way to stack while not having to reframe all the time.
I have been using my Df for asto photos, but would like to get away from leaving outside at night for long periods.. I love it for my other photo projects and would like to save it for those.
Thank you for the suggestion on getting the back-focus length correct!
and a very nice picture  :)
Art
