Author Topic: New Z8 and Z6 III firmware released  (Read 5743 times)
« on: February 26, 2025, 09:22:40 »
Z8 v. 2.10
https://downloadcenter.nikonimglib.com/en/download/fw/550.html
Installed without problems. Note that shooting mode of each bank is set to P immediately after install per Nikon's description, just takes a few seconds to set back to original preference.
Z6 III
https://downloadcenter.nikonimglib.com/en/download/fw/549.html
Re: New Z8 and Z6 III firmware released
« Reply #1 on: February 26, 2025, 15:42:37 »
thanks for the head up
« Reply #2 on: February 28, 2025, 12:32:58 »
Yes - Thank you! Will try out the Z8 update
« Reply #3 on: March 02, 2025, 01:46:32 »
A further comment that the reason for the shooting mode of each bank being set to P immediately after install, is that there are now separate parallel banks for video and stills, which is a great improvement but important to be aware of if one switches between these two modes:
While without much preparation taking a few shots during a dance performance at the Anchorage museum this week with my Z8 (https://nikongear.net/revival/index.php?topic=11160.msg205945#msg205945), I started out shooting video, and made note that the 85mm f/1.8 was wide open as intended for subject isolation. But when I quickly switched to stills I forgot that the A bank was at f/7.1 while video bank A had also been set to P mode by the firmware upgrade and thus kept the lens wide open to accommodate the low light levels. Thus I did not get the intended subject isolation for the stills. So during processing I grabbed some jpgs of the frames of that dance performance from the video shot in 4K 60p, which after all worked out well.
It is also worth noting that a switch of shooting bank in shooting mode will also switch to the parallell bank in video mode and vice versa.
« Reply #4 on: March 10, 2025, 13:39:18 »
Thank you for the heads up on that 'feature' ;)
Darkslide
  • Be patient - I'm new!
    • Ian Grandjean Photography
« Reply #5 on: March 10, 2025, 15:50:09 »
The shooting mode didn't change at all when I updated my Z8
Ian Grandjean
Cameras, lenses, stuff...
« Reply #6 on: March 10, 2025, 23:50:10 »
Same with me.
« Reply #7 on: March 11, 2025, 00:26:19 »
Interesting, it definitely did change to P mode with me in all the banks. The different banks were in A and M mode beforehand.
