Author Topic: Rare Fisheye Nikkor for Disney  (Read 6753 times)
Re: Rare Fisheye Nikkor for Disney
« Reply #1 on: January 17, 2025, 14:26:01 »
very interesting.... nice find Akira!..  I am no expert, but this is a first for me as well and according to the article the should be no surprise since only one was made.
« Reply #2 on: January 17, 2025, 17:59:02 »
Very interesting design, and the price signals this glass monster should never be used to do real photography for the fear of scratching the lens :)
The calculation to show this is an "f/2" lens was just stupid, though.
« Reply #3 on: January 17, 2025, 21:50:12 »
Maybe free shipping can be negotiated?
« Reply #4 on: January 18, 2025, 01:19:32 »
Glad you enjoyed the article, Bob!
I think they took the x0.51 factor into calculation of the focal length as well.
I thought the same way.   ;D
« Reply #5 on: January 18, 2025, 02:44:53 »
Petapixel later issued a "correction" explaining that the Leica Store Netherlands had written the stupid copy.
F2F3F6
« Reply #6 on: January 18, 2025, 14:59:18 »
Rare Nikon glass becomes even rarer when transformed for cine or astro use...2,0/300 IF-ED or 2,8/6 Fisheye are really unique ! Thanks Akira for this article  ;)
« Reply #7 on: January 18, 2025, 17:25:13 »
my thought is they missed the square root.  so for a image diagonal ratio of 0.51, (0.51)^1/2=0.7141, 0.7141x4=2.8566
I would like to know how to properly scale aperture as I have been using the Fuji GFX, so if I have this wrong let me know.
« Reply #8 on: January 18, 2025, 18:00:50 »
Glad you enjoy it!
« Reply #9 on: January 18, 2025, 23:02:16 »
There is no need to "scale" aperture. It stays put whatever the format. The same holds for image magnification. And image circle. And the angle of view of the design. And resolution.
What does change with the format is how much of what the lens "sees" that can be recorded onto film/digital sensor.
« Reply #10 on: January 19, 2025, 17:49:31 »
I think I might have been wrong on the square root.. no matter... back to your response.
what are your thoughts using f/64 on an 8x10 view relative to 35mm format.
« Reply #11 on: January 19, 2025, 18:02:07 »
Using f/64 on the 8x10" format is fairly OK, however would be a disaster on the 24x36mm frame.  Secondary magnification from the large format to the final print is modest, compared to what the smaller format would require. Hence the difference.
« Reply #12 on: January 20, 2025, 00:09:10 »
using a scale factor one would arrive at the 35mm equivalent of f/8.  is using scale factors in this way misleading?
« Reply #13 on: January 20, 2025, 07:35:43 »
The short answer: yes.
« Reply #14 on: March 13, 2025, 12:21:29 »
A sister Projector lens for your Camera lens   :o
17.3mm f/4 for 70mm Cine Projector I had the opptotunity to play a little with,,,
https://nikongear.net/revival/index.php?topic=7051.msg137057#msg137057
Note the serial numbers 112001 and 113001  8)
